Strange results changing trans fluid-help
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Strange results changing trans fluid-help in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I just changed the transmission fluid in my 2005 CTS 3.6. I got 5 quarts out of the drain plug, ...
    Pwayne is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Jun 2008
    185
    I got 5 quarts out of the drain plug, dropped the pan, cleaned it, changed the filter.
    BUT I COULD ONLY GET 3.5 QUARTS BACK IN the fill hole. -help-
    I jacked the car way up on one corner to push the fluid to the other side of the pan, but this only helped me get about another 1/2 quart in. I started the car and put it in gear hoping that this would make more room, but it did not.....So I am running around with 1 less quart than I took out.
    How in the world do I get more in there, there is no dip stick and it seems impossible to get the last quart in through the fill plug hole. I bought one of those pumps to pump it in the fill hole, works pretty good, but as I get close to pumping in the last quart, it starts pouring out the hole as fast as I'm puming it in.
    Please help I really would fill better if I could get the same amount in that I took out. Thanks, Wayne
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    Re: Strange results changing trans fluid-help
    IIRC, thats normal. You have to drive it for a couple minutes, and then go back and top up the fluid. I could be wrong tho...
    Jun 2008
    185
    I did start in and put it in drive and reverse for a couple of minutes, but I didn't drive it. Now that I've driven it for a few days I guess I'll see if I can get more in.
