If using hubcentric rings- front or back?
Results 1 to 2 of 2
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, If using hubcentric rings- front or back? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Okay so i've search all day and couldn't find an answer that you may think has been beaten to death. ...
    shmiddy's Avatar
    shmiddy is offline Cadillac Owners Fanatic
    Automobile(s): 3.6 DI CTS
    Jun 2008
    Ottawa, ON
    192
    So i have 2 winter tires on Steel Rims with the bolt pattern 114.3. I know i need hub centric rings to make them work.
    But i will be buying 2 Steel rims that will have the proper bolt pattern for the other 2 tires.
    My question is. Would it be better to have the proper fitting tires on the Front, or the Back?
    I figure the Back is where the power is, but the front has alot more strain on it cause of turning.
    And what kind/size hub centric ring do i need?
    Thanks in Advance for any help
    pjd951990 is offline Cadillac Owners Fanatic
    Automobile(s): They should make a new model name for mine but I guess a CTS
    Oct 2008
    Pennsylvania
    26
    271
    Re: If using hubcentric rings- front or back?
    I know this may sound like a retarded idea but why not be safe about it and order 4 wheels that all fit properly
