MPG (search function?)
Results 1 to 15 of 15
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, MPG (search function?) in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hi, Considering a 2003 CTS and was wondering what the mpg is like in real life. EPA says 16/24, but ...
    nuskool is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS w/ performance pkg, 18" wheel pkg
    Oct 2008
    52
    132
    Hi,
    EPA says 16/24, but my neighbor says he gets 32 hwy. (which is most every day for him) That's a big diff.
    We like the car a lot, but would like to see high 20's for hwy mpg.
    I looked for a search function but don't see a tab for that.
    Also would like to know how it is in the snow.
    Thanks
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    Re: MPG (search function?)
    High 20's is doable, assuming you have the auto. The gearing was more aggressive with the manual trans.
    The CTS will be fine in the winter with a set of good snow tires. Hills will give it trouble tho, especially since it doesnt have an lsd. Really, it will get anywhere a fwd can. It may be a little harder starting off, but once going you have much more control, especially in a slide.
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    the 03 3.2L is rated for 26mpg hwy, i get over that, probably 28-30 im light on the gas. also i think city its rated for 18-20mpg. go for ti, best car i have ever driven.
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    With premium gas and a tail wind, I get 32. I typically use mid-grade. combination of city/Hwy is about 24. I carry about 100lbs of books for work so I get good traction in snow with all season tires. The car has a 2nd gear start feature that helps. BTW, you can only go as fast as the car in front of you when it's snowing.
    mikes2nd is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Sep 2008
    50
    377
    im getting around 23-24 and i drive fairly aggresivelly. If I hypermile you can get alot. I was averaging 45
    I've noticed with an auto you can put the car in neutral and coast downhill and alot farther. Not sure how good it is for the tranny though.
    Obviously with a manual its easier on the tranny just by pushing in the clutch.
    PublicEnemy's Avatar
    PublicEnemy is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS 3.6L VVT
    May 2008
    North Vancouver, BC
    30
    149
    Quote Originally Posted by concorso View Post
    The CTS actually does have an LSD.
    Spyke's Avatar
    Spyke is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac CTS 3.6L VVT
    Sep 2007
    Montreal, QC
    1,062
    Quote Originally Posted by PublicEnemy View Post
    I dont!
    Coma's Avatar
    Coma is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS 2.8L
    Nov 2006
    Westlake, Ohio
    32
    2,471
    Quote Originally Posted by nuskool View Post
    You will see high 20's for highway mpg.
    It's not that great in the snow because of the light weight of the rear end, but it's no worse than the rest.
    May 2008
    North Vancouver, BC
    30
    149
    The sport package does
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    i dont think it did in 03.....mines a 03 lux sport
    also if you put bigger wheels on you will get more mpg hwy but less city, also put less miles on your car. but to do so for the reason of mileage on the car i believe is illegal....
    Dec 2007
    5,630
    Only 2006+.
    Dec 2007
    5,630
    Quote Originally Posted by ghettomike View Post
    Not entirely. Its actually the tire diameter that would affect the amount of miles put on the car, not the wheel size. The overall diameter would have to be larger, not just the tire.
    pick-a-part's Avatar
    pick-a-part is offline Banned
    Automobile(s): Lots of CTS-V's
    Apr 2007
    87
    and its not illegal... you can have the speedometer reflashed for the larger diameter tires, or get a speedometer tooth gear that matches your tire size properly.
  16. #14
    Dec 2007
    5,630
    Should say wheel.
  17. #15
    Sal33n's Avatar
    Sal33n is offline Cadillac Owners Fanatic
    Automobile(s): Former '03 CTS owner, 09' CTS4
    Apr 2008
    Ray, MI
    48
    109
    I have an 03 CTS with the 3.2l. Most of my driving is suburban commuting to and from work (24 miles each way) which is a mix of moderate to heavy traffic on surface streets and partly expressway. My average MPG fluctuates between 22.5 to 23.5. On long trips on the highway my average is 26-27 mpg at speeds of around 75-80 mph.
  18. Remove Advertisements
