headlamp questions, HID upgrade
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, headlamp questions, HID upgrade in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; After much time and thought I have some questions on headlights. My car does not have HID lights. if it ...
    jakhammer's Avatar
    jakhammer is offline Cadillac Owners Member
    Automobile(s): 2005 CTS 3.6l
    Feb 2008
    coleman, mi
    75
    After much time and thought I have some questions on headlights. My car does not have HID lights. if it does, they dont have the bluish glow like any of the others I have seen. Now if i wanted to upgrade my low beams to a HID setup, what would it take? I am clueless on everything HID. can I just swap some aftermarket lamps in or do I need supporting wiring to go with them? Any help is much appreciated.
    Chris
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,038
    Re: headlamp questions, HID upgrade
    Here's HID 101:
    If you do not have HID headlamps you'll need a complete HID retrofit kit. This kit includes 2 HID lamps, 2 ballasts, and the associated wiring. The kit you'll need to replace the low beams will be 9006. These kits are plug-n-play and very easy to install. Generally a quality kit with both replacement bulbs can be had for $100 or less. If you can read instructions and plug a male into a female plug you can install them yourself. Stay away form Japanese and Chinese Ebay vendors unless you want to buy junk HIDs with NO WARRANTY.
    HIDs are a great replacement for low beams. They aren't practical for high beam replacements because high beams are cycled on and off too frequently. Constantly turning HIDs on and off will shorten the life of the bulbs and can ruin your ballasts. HIDs also look great in foglights.
    Temperature:
    Pure white HIDs are in the 4000-5000k range, these will offer you the most USABLE and white light output. HIDs in the 6000k range have approximately 5% blue tint to them, and these are the highest PRACTICAL temp lights because usable light output is still very good in this range. HIDs in the 7000-8000k range will have a significant blue'ish coloring to them, but useful light output begins to fall off significantly. Anything over 9000k will begin to take on a purple coloring, and useful light output will SUFFER badly.
    Where to buy? We have a vendor here that sells retrofit plug-n-play kits with good warranties.
    http://www.cadillacforums.com/forums/sharp-hid/
    http://www.sharphid.com
    But there are thousands of sellers online and on flee-bay. Buyer beware on Ebay. Hope that helps some.
    The above post is my 2 cents....nothing more.
    jakhammer's Avatar
    Feb 2008
    coleman, mi
    75
    Thanks for the help. I think I will be buying a 6k 35w kit for the low beams. I might pick up another for the fogs, but that will be later.
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,307
    go ahead and buy the kit for the fogs and do them at the same time, the bumper will be off anyway. Cause when you fire up the the new headlights and the fogs don't match....
    gaugeguru's Avatar
    gaugeguru is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS
    Aug 2007
    Toronto
    35
    247
    Actually, most high end cars use halogens in the fogs even though the low beams are HID.
    I read that Halogens are better suited for fogs with wet road conditions because of less glare.
    It's too bad our fogs weren't like the STS fogs with a projector. There's something about a big rectangular fog light glowing a yellowish white that just doesn't look that good.
    Then again, I think the 8000K installed in our fogs doesn't make things look all that better. It's pretty obvious the color is not from a projector, it's from a colored bulb or aftermarket HID kit in a cheap halogen reflector housing. Makes me think of a teenage rice rocket.
    Coma's Avatar
    Coma is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS 2.8L
    Nov 2006
    Westlake, Ohio
    33
    2,471
    It actually looks sick when you put in 6,000K's in the top and bottom. I personally am not a fan of anything bluer.
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    I agree with the 6k top and bottom and a white LED in the trainagle( shows blue ) all three have a nice look.
    jakhammer's Avatar
    Feb 2008
    coleman, mi
    75
    Quote Originally Posted by Sammy Z View Post
    very nice. I do think that is the way Im going to go. Thanks for the pic.
    Chris
    Rolex's Avatar
    Arkansas
    41
    12,038
    Those are a great match. Well done.
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,307
    the 6k in the low beam and the fogs and the led's is what i have in mine. the picture is not the greatest, but they match great and give the car a much better look.
    Acqua7's Avatar
    Acqua7 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac CTS 3.6
    Jan 2007
    NJ
    32
    281
    the ones in my sig is 8K around
    Rolex's Avatar
    Arkansas
    41
    12,038
    Quote Originally Posted by Acqua7 View Post
    They have a great looking purple/blue color, but their light output looks weak. They don't appear to illuminate the ground directly in front of the car very well IMO. Put a set of 8-9k next to a set of 4-5k and the difference is significant.
    Acqua7's Avatar
    Jan 2007
    NJ
    32
    281
    Quote Originally Posted by Rolex View Post
    yeah the picture would indicate that...but get in the car and its a different story, those lights, you can see everything no problem, nice and bright
  16. #14
    Coma's Avatar
    Nov 2006
    Westlake, Ohio
    33
    2,471
    Only when you start to get into the 10,000K and 12,000K temperatures do you see an obvious lack of illumination. 8,000K still has decent light output when compared to 4,300K or 6,000K. Any way you look at it though, they are all going to be brighter than halogen bulbs.
    What the hell, might as well post it again...
    Should have taken the flash off for this. Stupid camera phone! >.<
  17. #15
    Rolex's Avatar
    Arkansas
    41
    12,038
    I certainly didn't mean to hate on your lights. They look great and (arguably) 8k are better suited for driving inside city limits where you have a lot of light interference and reflective street signs. Either way (as said above) they're a damn sight brighter then the factory lamps.
  18. Remove Advertisements
