headlamp questions, HID upgrade - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, headlamp questions, HID upgrade in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Originally Posted by xocomaox Only when you start to get into the 10,000K and 12,000K temperatures do you see an ...
  1. #16
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    Re: headlamp questions, HID upgrade
    Quote Originally Posted by xocomaox View Post
    Only when you start to get into the 10,000K and 12,000K temperatures do you see an obvious lack of illumination. 8,000K still has decent light output when compared to 4,300K or 6,000K. Any way you look at it though, they are all going to be brighter than halogen bulbs.
    What the hell, might as well post it again...
    Should have taken the flash off for this. Stupid camera phone! >.<
    This is very arguable. Even 8k will drop below 2000 lumens after its used for a 100hours or so, whereas a 4300k will still be around 3000. Not only that, a bluer light needs to be brighter then an equivalent whiter bulb, simply because your eye recognizes yellow-white better then any other color. Enables you to see more, even tho the lumens may be the same...
  2. #17
    Coma's Avatar
    Coma is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS 2.8L
    Nov 2006
    Westlake, Ohio
    32
    2,471
    I'm just going by what I've seen, real world. You can argue about the science of it all you want.
  3. #18
    Dec 2007
    5,630
    Except you can't argue with science... Thats like saying a 40 gal drum of oil is a large as a 50 gal drum of oil, simply because you believe it to be so! Light meters dont lie.
    I can understand the attraction, it looks cooler. But IVe been doing HIDS for 10-12 years now. Ive proven this idea many many times to friends, at least 4 times I can think of, off-hand. I know with the CTS it would be hard to compare 2 different light outputs at once, since its alot of trouble to get the bumper off. But if you ever get the chance to compare them side by side, youll see exactly what I mean.
  5. #19
    Coma's Avatar
    Nov 2006
    Westlake, Ohio
    32
    2,471
    Although I don't agree with your analogy, I can see what you're saying.
  6. #20
    TotalEclipse31's Avatar
    TotalEclipse31 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS VTXi
    Apr 2008
    Maryland
    34
    310
    I think to some people the color is more important the usable light output.
  7. #21
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,034
    Quote Originally Posted by TotalEclipse31 View Post
    This is absolutely true. This is why I don't recommend people buy over 6k when retrofitting HIDs. JMHO
    The above post is my 2 cents....nothing more.
  8. #22
    Coma's Avatar
    Nov 2006
    Westlake, Ohio
    32
    2,471
    The problem I see with 8K's are the fact that they don't match white LEDs. And white LED's are the shit!
  9. #23
    YuraB is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Nov 2007
    631
    I got 6,000k on my car and the light output is pretty damn blue.
    If you want the oem baby blue color get 4300k. The light output is actually yellowish white, but it looks blue. I will explain: HID lights produce a way higher range of spectrum of light then halogens. So when they are shined through curvy lenses in the low beam housing, when you are looking at the sides they look blue. The only time they look yellow/white is when you are directly in front of them. I don’t know any cars that actually produce their beams at 6000k stock, all have 4300k because of the significantly higher lumins. Get 4300k in your lows, and 6000k in your fogs and highs.
  10. #24
    gaugeguru's Avatar
    gaugeguru is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS
    Aug 2007
    Toronto
    35
    247
    That is a good point.
    Don't go overboard with the color. It will make your car look a teenage aftermarket disaster.
    No high-end car would ever have 8000k. It simply doesn't make sense. It is fatiguing on the eyes and produces too much glare.
    The whole obsession with color comes from the fact that the light from high-end cars with projectors shows color from an angle.
  11. #25
    jakhammer's Avatar
    jakhammer is offline Cadillac Owners Member
    Automobile(s): 2005 CTS 3.6l
    Feb 2008
    coleman, mi
    75
    lots of good info in here. thanks for all the input. i may do 5k. I will for sure be doing higher than 4300 though. I want white light, i hate yellowish light, it annoys me. I have Silverstars in my Lightning for heads and fogs and I want something around that color. im guessing 5k will be close on the yellow side and 6k will be close on the blue side. Any thoughts?
    Chris
  12. #26
    gaugeguru's Avatar
    Aug 2007
    Toronto
    35
    247
    I have 5000K installed on mine. It's a lot bluer than you would expect when seen through the projectors.
    I'm thinking of going 4300K now that one of mine burned out, but I'm not sure.
    Right now, I have halogen in one light and HID in the other. I get a lot of stares!
    The halogen light is actually really good. It has good range and lights things up nice.
    The big difference with HID is the road signs, reflective coatings on trucks / busses and the paint markings on the road. It doesn't matter how far the sign, it glows with this cool purplish reflection. When I turn my lights off, and only the halogen lights from the cars around me are on... The signs are barely readable.
    I've seen 8000k and 10,000K HID, and I don't mean to hate, but it looks obnoxious to me. My eyes get irritated, even when not staring directly at the light.
    5000K matches the LED corner lights well.
    I've taken the projector out of an STS fog and will attempt to retrofit it into the CTS housing. If it works, I will probably go with 4300K. Even the halogen light appears slightly purple through these projectors
  13. Remove Advertisements
