Results 1 to 7 of 7
Thread: Brake light trouble
    kyarbough is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    3
    Exclamation Brake light trouble
    I have a 2005 CTS and both the left & right brake lights do not work. The center/trunk lid light works though. I have replaced the bulbs and the parking lamps work fine. All fuses appear to be ok...what else could be the problem?
    Kevin
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    Re: Brake light trouble
    Do you have the correct bulbs it there? Try turn them around
    Sep 2008
    3
    There is no power on the white wires entering the light sockets. They worked when I purchased the car and I have never replaced them.
  5. #4
    Sep 2008
    3
    I can't figure out why the 2 rear side brake lights don't work. All fuses are good and the bulbs have been replaced. Anyone have any ideas? How do I check the switch and where is it located?
  6. #5
    TotalEclipse31's Avatar
    TotalEclipse31 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS VTXi
    Apr 2008
    Maryland
    34
    310
    I had this same issue. I went to dealer under warranty and what happened was the light housing actually leaked moisture and the harness got burnt up. They had to replace some harness and the light housing.
  7. #6
    Sammy Z's Avatar
    Jan 2008
    Chicago, IL
    1,765
    I think that if the center light is working, the switch is working.
  8. #7
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    you may need to use a volt meter and check to see if any power is getting to the wires at all by the outlet, wedge something on the brake peddle so the light SHOULD be on
  • You may not post replies
