Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS First Generation Forum - 2003 - 2007
Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: Aisin MT Problems
Old 09-10-08, 01:27 PM
Cadillac(s): Cadillac
View RedBear's Photo Album
Casino Cash: $310
Question Aisin MT Problems
I'm having problems with my 2005 CTS Aisin manual transmission. In higher gears when I accelerate, the engine overrevs and then drops back to where it should be. I took it into the dealer and he said everything was OK. Now I'm getting some grinding in 1st gear occasionally, and it's starting to over rev in 3rd gear as well when I accelerate. The car only has 30K miles and my wife drives it most of the time, and mostly around town. In addition, the cruise controls drops out, probably because the engine over-revs trying to speed up.
I'ts still under warranty and I'm taking it into the dealer again tomorrow.
Any suggestions?
Thanks
  #2 (permalink)
Old 09-10-08, 02:25 PM
my name is Tiffany
Cadillac(s): 05 CTS-V
View urbanski's Photo Album
Casino Cash: $1133630
Re: Aisin MT Problems
sounds like a clutch to me
  #3 (permalink)
Old 09-10-08, 03:11 PM
Cadillac(s): '05 Cadillac CTS - Blacked out
View mrc00l88's Photo Album
Casino Cash: $1950
let me know if it turns out to be the clutch. i have 30k on my 6 speed 2005 as well.. no grinding for me, but when i put it in 4-5 or 6th it revs to like 3 then drops back down...
is the clutch under warranty or no?
  #4 (permalink)
odysseus's Avatar
Cadillac(s): 2003 CTS Manual Trans., '93 STS
View odysseus's Photo Album
Casino Cash: $6897
Ditto on the clutch. It's the only thing in the system that can slip. The drivetrain from the engine to the rear wheels is pretty much locked in place by gears and shafts, other than the clutch.
  #5 (permalink)
Old 09-10-08, 03:17 PM
Casino Cash: $1950
is the clutch under warranty?
  #6 (permalink)
Old 09-10-08, 03:33 PM
yomommas's Avatar
Cadillac(s): '04 CTS, '79 Coupe DeVille, '78 Sedan De Ville, '77 Firebird
View yomommas's Photo Album
Casino Cash: $4503
ditto on the clutch and i pray you've got a warranty. i just spend $2200 to replace mine.
  #7 (permalink)
Old 09-10-08, 05:02 PM
Casino Cash: $310
Although retired military, she's the reason I'm voting for Obama. And, yes, I think it's the clutch.
  #8 (permalink)
Old 09-10-08, 05:06 PM
Casino Cash: $310
Yes, thankfully we got an extended warranty, or maybe it's still under the original warranty. We are in the flatlands of OH, and now in cruise control, when we go over an overpass, the cruise drops out probably because the engine revs up too much.
  #9 (permalink)
Old 09-10-08, 05:10 PM
Casino Cash: $310
Thanks. Yes, I'm an engineer and agree with you and have driven MT for always. I told the local dealer that the clutch was slipping but was told all was well a few months ago. Tomorrow we'll find out.
  #10 (permalink)
Old 09-10-08, 05:14 PM
Casino Cash: $310
Yes, we got the extended warranty because we usually keep a car 10 or so years and maybe the car is still even under the original warranty. were your transmission problems the same as I described. Thanks.
  #11 (permalink)
Old 09-10-08, 05:58 PM
BlueMalibu's Avatar
Cadillac(s): '07 CTS 3.6 Sport, 6-Speed
View BlueMalibu's Photo Album
Casino Cash: $810
Wow, sounds like clutch. Probably going to be considered a "wear item" on your warranty - just like brake pads.
Have 43k miles on my '07 and no clutch troubles yet.
Anybody else have their clutch replaced and at what mileage?
  #12 (permalink)
Old 09-10-08, 07:40 PM
yomommas's Avatar
Casino Cash: $4503
hope you're still under warranty (or have a GOOD extended warranty). my extended warranty didn't cover it. although it did cover my broken u-joints and a few other miscellaneous (cheap) things that also needed fixing while my clutch was getting fixed.
  #13 (permalink)
Old 09-11-08, 05:27 PM
Casino Cash: $310
Yes, the dealer says it's the clutch. The problem started in the higher gears and then became apparent in the lower gears. Try stomping on the gas at about 65 or so in 6th gear and see if the RPMs go up dramatically. It strted there and eventually became even apparent in 2nd gear. The repairs are being done under warranty. I had a 4-year original warranty and we are still in that period. I also have an extended warranty but don't know if it would be covered.
  #14 (permalink)
Old 11-19-08, 11:37 AM
BlueMalibu's Avatar
Casino Cash: $810
Well, my '07 just started slipping yesterday. Was accelerating onto the freeway in 5th when the slipping began. I can repeat by accelerating full throttle from 3000 RPM in 5th.
Car has 48K on the clock so I hope this truly can be a warranty repair. I also have the 4 year warranty.
The clutch should not fail this early and I suspect the actual problem is the pressure plate.
  #15 (permalink)
Old 11-19-08, 02:08 PM
jpo96sungt's Avatar
Cadillac(s): Cadillac CTS
View jpo96sungt's Photo Album
Casino Cash: $2495
Driving style determines how long a clutch lasts. Try not to slip the clutch very much, engaging the clutch quicker is actually better even though it is jerky. Leave the car in neutral and don't hold the clutch depressed(wears out the throw out bearing) at a light. If you can, rev-match as much as possible. By this I mean if you are down shifting blip the throttle to about 3000-3500 rpm as you let out the clutch. Matching rev's dramatically increases the longevity of the clutch. Also skip gears you don't need, the fewer shifts the less clutch wear. my .02 cents. Hopefully it make cents...See what I did there.
Tags: ,
aisin, problems
