trans issues after TSB flash
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, trans issues after TSB flash in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I currently have a 04' CTS LUX with 44k miles that I got about 3 weeks ago. long story short. ...
    domokun is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    33
    27
    I currently have a 04' CTS LUX with 44k miles that I got about 3 weeks ago. long story short. when I first got the car, when the car was cold, I could feel the car downshift ( say doing 50 and coming to a stop light, and I hit the brakes, I could feel the car go from 4th to 1st ) I also got the 40-55mph chug. so I did a search and seen taht it was a issue on a lot of cars, so GM came out with the TSB. well my Ex GF's dad worked ( he just quit yesterday ) for a gm dealership so he flashed my car for the TSB for the new trans module and the new engine PCM update.
    well after doing those 2 things, its seems the transmission is slipping ( warm or cold ). say Im leaving a stop light. I push the pedal 1/2 way. the car will go ( wont slip ) but right when it shifts from first to second, I can hear the car shift, but it till hang, then kinda take a while to shift (1sec-1.5 sec, not smooth like it should ) then FINALLY it shifts, in the mean time the RPMS jump up about 300-500 after this shift. also if I push the pedal a lil harder in the middle of the shift, it will bang the gear where it actually jerks the car. ( seems to do this for 1-2 and 2-3 sometimes )
    do you guys have any ideas? I DO know the transmissions has a lil learning time, but Ive put on a good 100 miles since the flash with the same issue. also, sport mode shifts fine. do you think the flash didnt upload correctly? or the trans is Eff'ed up? trans fluid is low?
    thank you in advance
    also, any guys taht DID get this flash, can you tell me what you experienced? thank you
    Spyke's Avatar
    Spyke is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac CTS 3.6L VVT
    Sep 2007
    Montreal, QC
    1,062
    Re: trans issues after TSB flash
    dont worry.. when I updated the pcm or ecm or whatever cm they have in our car, the transmission seems to slip for approx 1000 kms (600 miles or mabe a little less then 600). So just dont worry about it. Its learning and learning and learning. Dont worry I think they did a great job, but I know its a weird feeling!
    Aug 2008
    33
    27
    are you sure about that? did yours really do this for about 500 miles?
    I thinking Im going to take the car in to get an alignment ( need one anyways ) and get the trans serviced, and get the rear fluid swapped for some amsoil gear oil ( I got the whine )
    Spyke's Avatar
    Sep 2007
    Montreal, QC
    1,062
    I'm 100% sure about that. Even my girlfriend was like: give it a try for another 300 miles and then, if the problem is still there, go back at the dealer. But everyday, the problem seems less present (it was learning. It would wait a lot before shifting to make sure you don't press the accelerator harder).
    549 miles to be exact on the weird transmission shifting (I checked my odo reading on both bills from dealer at one week interval)
    bo3adsa is offline Cadillac Owners Fanatic
    Automobile(s): White diamond 05 CTS 3.6L Euro
    Apr 2007
    Kuwait
    181
    I agree with spyke.
    Your car is learning based on your driving behavior. By time you will feel the shifting is much better. The only good advice is to warm-up your car in the morning at least 5 min before driving I found the shifting get much smother that way..
  8. Remove Advertisements
