Results 1 to 2 of 2
Thread: Volant Intake 05 Question..
    mrc00l88 is offline Cadillac Owners Fanatic
    Automobile(s): '05 Cadillac CTS - Blacked out
    Aug 2008
    NJ
    152
    Exclamation Volant Intake 05 Question..
    Do they make a model for the 2.8L? Or would the 3.6L be the same application?
    odysseus's Avatar
    odysseus is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS Manual Trans., '93 STS
    May 2004
    Yorktown, VA
    54
    3,035
    Re: Volant Intake 05 Question..
    I don't have either motor, but the 2.8 is a smaller stroke/bore version of the 3.6. One would assume the intake tube is identical, and therefore the Volant for a 3.6 would be plug and play. Look at your motor and compare it to pictures under the hood of a 3.6 to be sure. Basically, you transfer your MAF to the new airbox and swap them. The intake tube is a nice to have, but you could use your existing one in a pinch with little effect.
    FYI, the airbox is identical between the 3.6 and even the Opel derived 3.2 motor. It's the plastic intake tubes that vary. The 3.2 was only used for 2 years, and is a completely different motor.
  • You may not post replies
