Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS First Generation Forum - 2003 - 2007
Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: Air Bag Solution
Old 05-27-08, 07:50 PM
Cadillac(s): 2003 Cadillac Cts
View kissdaring's Photo Album
Casino Cash: $1615
Air Bag Solution
so i took my 2003 cts to the dealer today to have the air bags and the light thats always On looked at..
this is what was said
test for airbaglight on. scan car with Tech2 & found no communication with SMD. check fuse. OK. also found DTC U1088 in onstar odule. check for PSB & PI. found PSB #02-09-41-003. new SMD & front sensor required...
what would you att think i should do
where to get the parts and what should i get first
thanks.
  #2 (permalink)
Old 06-03-08, 06:18 PM
Casino Cash: $1615
Re: Air Bag Solution
anybody????
  #3 (permalink)
Old 06-03-08, 06:53 PM
dkozloski's Avatar
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $20257
Because of the history of trouble with this circuitry in other '03 CTSs, I'd check the airbag and SMD wiring inch by inch for starters. A broken/pinched wire or corroded connector would give you the same symptoms and can be fixed for nothing but labor. Why swap parts and find out it still doesn't work and still have to fix the wiring?
Don't mess with Binky Bear!
  #4 (permalink)
Old 06-03-08, 07:36 PM
bigblockcadillac's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2003 Cadillac CTS Luxury Sport
View bigblockcadillac's Photo Album
Casino Cash: $2399
I don't know if this helps, but I had the "service the air bag" come on about a year ago. It turned out to be a bad air bag module under the passenger seat. The dealership wanted about $800 to replace parts and labor, but I had a warranty. good luck
  #5 (permalink)
Old 06-03-08, 07:54 PM
Casino Cash: $1615
ummm the wiering are way to long to check and they are under the carpet how do io get in there with out taking the seats and carpet out...
  #6 (permalink)
Old 06-03-08, 08:17 PM
dkozloski's Avatar
Cold Soaked
Casino Cash: $20257
It's an expensive and difficult repair. Welcome to luxury car ownership. If you want to dance, you have to pay the piper.
  #7 (permalink)
Old 06-03-08, 09:36 PM
View 04deveni's Photo Album
Casino Cash: $2330
...or get piped
I had to throw that one your way Marcy ;-)
  #8 (permalink)
Old 06-04-08, 07:39 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
First of all... if that is the way it is really written on the RO I'd be tempted to find another dealership.
If those are type-o's then you are both forgiven.
That bulletin (TSB) does put 2 and 2 together and it would seem based on the information that I can translate out of that the vehicle may need an "SDM" (not SMD) and a sensor as the tech indicated.
#02-09-41-003: Air Bag Indicator Illuminates Intermittently, IPC and Sensing and Diagnostic Module (SDM) DTC U1000 Set (Replace Front End Sensor Assembly and/or Sensing Diagnostic Module) - (Oct 14, 2002)
Subject: Air Bag indicator Illuminates Intermittently, IPC and Sensing and Diagnostic Module (SDM) DTC U1000 Set, OnStar® System DTC U1088 Set (Replace Front End Sensor Assembly and/or Sensing Diagnostic Module)
Models: 2002-2003 Cadillac DeVille Built Prior To VIN Breakpoint 3U159084
2003 Cadillac CTS Built Prior To VIN Breakpoint 30131856
Condition
Some customers may comment that after starting the vehicle, the Air Bag Readiness Light/Indicator on the instrument panel cluster (IPC) flashes for a few seconds (6-10 times) and then remains illuminated until the next ignition cycle.
Technicians may find a SDM and IPC U1000 DTC and an OnStar® System U1088 DTC set in history.
Cause
This condition may be due to a unique Class 2 communication software issue within the Sensing and Diagnostic Module (SDM).
Correction
Use the scan tool to:
• Perform the standard SIR diagnostic system check in order to verify the condition. Refer to Diagnostic System Check-SIR in the SIR sub-section of the appropriate Service Manual.
• Obtain the part number of the existing SDM.
On CTS models only, obtain the part number of the existing inflatable restraint front end sensor.
If the scan tool displays DTCs U1000 and U1088 and the existing SDM part number is NOT listed in the Parts Information table in this bulletin, go to Step 5 for DeVille and Step 6 for CTS.
If the scan tool does NOT display DTCs U1000 and U1088, perform the diagnostic procedure as indicated in the Diagnostic System Check-SIR in the Service Manual.
For DeVille models, replace the SDM only. Refer to the Inflatable Restraint Sensing and Diagnostic Module Replacement procedures in the SIR sub-section of the Service Manual.
For CTS models:
• Replace the SDM. Refer to the Inflatable Restraint Sensing and Diagnostic Module Replacement procedures in the SIR sub-section of the Service Manual.
• If the existing front end sensor is NOT P/N 25744736, replace it with P/N 25744736. Refer to the Inflatable Restraint Front End Sensor Replacement procedures in the SIR sub-section of the Service Manual.
Parts Information
Model
Part Number
Description
DeVille (With RPO AW9)
12232120
Module Asm-Inflatable Restraint Sensing & Diagnostic
DeVille (With RPO AJ7)
12232110
CTS
12232130
CTS
25744736
Sensor Asm-Inflatable Restraint Front End
Parts are currently available from GMSPO.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
Tags: , , , ,
air, bag, solution
