Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: HID kit installed
04-20-08, 01:59 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS | | Join Date: Aug 2007 Location: Toronto Age: 28 | | | HID kit installed I finally decided to get the xentec HID kit (5000K) on Wednesday night. I bought the kit on eBay just before Wednesday midnight. I got the kit about 36 hours later all the way from California to Toronto Canada!
That is definitely the fastest shipping if had so far on eBay since I've been a member in Jan 2004.
Here are my comments about this kit...
1) Connectors / plugs /sockets and wire were very high quality. The plugs had this sort of special rubber seal which looked like a triple gasket. Everything clicked together with a real tight fit. Overall, the quality was better than all the OEM stuff on the car.
2) The ballasts were heavy, solid and very compact. They had 3 tapped holes each for mounting. They were unlabeled with only a patent number on them.
3) The bulbs were clean and well packaged with solid connectors (all with the special rubber seal
4) Instructions were kind of funny but thorough
5) Packaging - Everything was properly packed with boxes inside boxes and the box was much smaller than it looked in the pictures
6) Performance - I got the 5000K kit (Just a little higher than OEM). At first I thought that I got the wrong bulbs because everything looked so purple / blue compared to what I thought. When I looked at the bulb directly, it looked very white, but at an angle, it looked purple / blue because of the projector.
It's exactly what I was looking for in terms of color. All the reflective paint on the road glows as if a black light was shining on it. Near the cutoff, you can see even more color.
7) Installation - I probably broke the rules here but I did not have to drill any holes. The kit was so small that I mounted the hole thing in the light housing. The ballast only gets slightly warm compared to the old halogen bulbs so I don't see any concern in terms of overheating / condensation. |
04-20-08, 02:02 PM
|  | Cadillac Owners Enthusiast Cadillac(s): '03 White Diamond Cts | | Join Date: Mar 2008 Location: Tampa, Brandon, Plant City | | | Re: HID kit installed Damn... how small was the ballast? |
04-20-08, 04:01 PM
|  | Cadillac Owners 10000+ Posts Cadillac(s): > BMUU | | Join Date: Mar 2007 Location: jersey | | | Re: HID kit installed |
04-20-08, 05:24 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac cts | | Join Date: Oct 2007 Location: NJ Age: 24 | | | Re: HID kit installed :mediumbanana |
04-20-08, 05:25 PM
|  | Cadillac Owners Enthusiast Cadillac(s): '03 White Diamond Cts | | Join Date: Mar 2008 Location: Tampa, Brandon, Plant City | | | Re: HID kit installed Quote:
Originally Posted by the cadillac kid | Yeah, what he posted.. |
04-20-08, 08:30 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS | | Join Date: Aug 2007 Location: Toronto Age: 28 | | | Re: HID kit installed You guys and your pics.... I will post some when I get a chance. |
04-20-08, 08:31 PM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | Re: HID kit installed Quote:
| YEA!!
HIDs are cool though, once you get them you dont understand how you were ever without them. |
04-20-08, 09:07 PM
|  | Cadillac Owners Enthusiast Cadillac(s): '03 White Diamond Cts | | Join Date: Mar 2008 Location: Tampa, Brandon, Plant City | | | Re: HID kit installed Ill admit it, Im a whore for pictures.. |
04-20-08, 09:29 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2007 Cadillac CTS 3.6L Black, LOADED | | Join Date: Apr 2007 Location: Queens, NYC Age: 26 | | | Re: HID kit installed Quote:
Originally Posted by the cadillac kid |  |
04-20-08, 10:06 PM
| | I SKYDIVE Cadillac(s): 03 Caddy CTS | | Join Date: Dec 2006 Location: Toronto Age: 25 | | | Re: HID kit installed i was thinking into getting one but.... does it really make that much of a difference? |
04-20-08, 10:37 PM
|  | Cadillac Owners 10000+ Posts Cadillac(s): > BMUU | | Join Date: Mar 2007 Location: jersey | | | Re: HID kit installed yep. |
04-20-08, 11:49 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS | | Join Date: Aug 2007 Location: Toronto Age: 28 | | | Re: HID kit installed It was last on my priority list but I would have done it earlier if I had known what a difference it would make. I did have to use the extra wire supplied to flip the polarity but it only took a minute. |
04-21-08, 12:17 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 CTS 2.8L | | Join Date: Nov 2006 Location: Westlake, Ohio Age: 25 | | | Re: HID kit installed Do not put ballast in headlight housing. Thank you. |
04-21-08, 08:23 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac cts | | Join Date: Jul 2007 Location: Downey,Ca | | | Re: HID kit installed ...i installed 6000k hid Xentec kit two weeks ago.
i had to drill holes into my light tops...to run to wire out from the bulb connection..
to my ballast...and back to the light..
who did you install without drilling holes...
please explain!! |
04-21-08, 09:26 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS | | Join Date: Aug 2007 Location: Toronto Age: 28 | | | Re: HID kit installed I put the whole kit in the headlight housing. Bulb, ballast & igniter.
I bought a newer digital kit with slim ballast. There's enough room for 2 kits easily.
It went in very neatly with out having to drill holes. I could remove the whole kit and you'd never know anything was ever there.
The hid kit, including ballasts produces far less heat than halogen, so I'm not worried about the housing getting too hot. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
