Page 1 of 5 12345 LastLast
Results 1 to 15 of 67
Thread: Front V bumper & New fog lights
    Nov 2005
    Augusta, GA
    33
    413
    Are the stock fog lights compatible with the front V bumper? I have the clear fog light lenses coming and just finally decided I wanted the lower bumper.
    stevbo200's Avatar
    stevbo200 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac cts, cadillac deville dts
    Oct 2007
    NJ
    32
    201
    Re: Front V bumper & New fog lights
    they are, and a few members have done it before, but its not plug n play, only the cts v lights are, even the sts v lights need a little modding.
    Nov 2005
    Augusta, GA
    33
    413
    What all has to be done to make the stock CTS lights fit?
  5. #4
    SvB4EvA's Avatar
    SvB4EvA is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 Cadillac CTS 3.6L Black, LOADED
    Apr 2007
    Queens, NYC
    34
    2,424
    Quote Originally Posted by Cadiman1983 View Post
    The fogs them selfs will fit fine... It is the brackets that attach to the bumper that the fogs are in that are the problem.
    I dont know exactly what you would need to do to get the CTS fog brackets onto the V bumper, but some say they have done it. I would assume it isnt that easy.
  6. #5
    gaugeguru's Avatar
    gaugeguru is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS
    Aug 2007
    Toronto
    35
    247
    Actually, it's very easy. I just did it on Monday using the regular CTS bracket.
    The CTS bracket is fastened to regular bumper at 3 locations...
    1) Top - inside
    2) Side
    3) Bottom Center
    #1 will screw into the V bumper in exactly the same spot, but #2 and 3 will NOT line up with any holes in the V bumper.
    Start by attaching the bracket using the original screw for hole #1.
    Remove the metal clip on hole #3 (bottom of the fog bracket) and you will have room for a 1/4" Stainless Steel machine screw. Drop the screw through the hole and mark where it hits the bumper with a marker. You will find that the screw hits a spot on the lower inside bumper flange where the wind dam covers. There is a gap of just over an inch between the hole on the bracket and the inside of the bumper.
    Drill a hole using an ordinary 1/4" bit and fasten the screw (2"-2.5" long) to the bumper using a Stainless washers / nuts passing the screw through the hole in the bottom of the fog bracket. Then clamp from both sides with compression washers / nuts (all stainless).
    Hole number 3 is not necessary and is not used.
    It took me about 10 minutes for mounting both lights after pondering for several hours with my friend of what the best move would be.
    At first I was worried about drilling through the bumper, but it is very easy to drill a neat hole in precisely the right spot. It doesn't matter anyway since the fog light is actually bigger than the opening. This allows for some misalignment of the bracket. The housing is also adjustable (pivots) on the bracket with a set screw if you wanted to fine tune the angle.
    I just could not fork out over 500 bucks plus Canada Customs to buy the V bracket from gmpartsdirect.com. I only paid $420 for a painted V bumper! For $500 I could get a good HID kit plus a spoiler.
  7. #6
    cts-tom is offline Cadillac Owners Member
    Mar 2008
    94
    nice write up! it will help me getting mines fixed
  8. #7
    Mar 2008
    94
    can you post close pic of the final installation please
    thanks
  9. #8
    BABYJ_Y2G's Avatar
    BABYJ_Y2G is offline Cadillac Owners Member
    Automobile(s): 04 Cadillac CTS Lux Sport Pack
    Oct 2007
    Philly
    80
    Good write up... this might be slightly off topic but does the splash plate (or whatever its called) from the CTS bumper fit on the CTS-v, or is that something you have to order seperatly?
  10. #9
    gaugeguru's Avatar
    Aug 2007
    Toronto
    35
    247
    You don't need anything except the bumper and lower grille. Everything else is the same including fender liners and wind dam.
    I did not take any pics, sorry.
  11. #10
    BABYJ_Y2G's Avatar
    Oct 2007
    Philly
    80
    Quote Originally Posted by gaugeguru View Post
    It's cool, thanks for the info...
  12. #11
    honey-ham's Avatar
    honey-ham is offline Cadillac Owners Member
    Automobile(s): 05 CTS
    Jun 2006
    San Diego, CA
    71
    Thumbs up Re: Front V bumper & New fog lights
    Excellent write up... exactly what I was wanting to hear too! I just couldn't see buying V brackets or even STS brackets for that matter. Thanks again!
  13. #12
    Mar 2008
    94
    1) Top - inside
    2) Side
    3) Bottom Center
    Hole number 3 is not necessary and is not used. .
    i'm a lil bit confused... is the number 3 holes not neccesary or what? you first mention the modification needed for the #3 and then : Hole number 3 is not neccesar and is not used..
  14. #13
    87vertgt Guest
    Question Re: Front V bumper & New fog lights
    Quote Originally Posted by cts-tom View Post
    The 3 screws are needed or else your fogs will rattle when driving...
    hole #3 needs to be made.....simple...you can get a plastic piercing screw for that...
    I think that answer's your question??? or maybe just confuse's ya ;-)
    Let me ask....have you disassembled it?
  15. #14
    Mar 2008
    94
    i've got the fog and the cts-v bumper in front of me
    do i need the disabblemt the bracket from the fog?
  16. #15
    87vertgt Guest
    no
    you can bolt it on with it.....saves time too....
  • You may not post replies
