Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: Sway Bars On 03 3.2L
04-10-08, 01:02 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2003 CTS Manual Trans., '93 STS | | Join Date: May 2004 Location: Yorktown, VA Age: 47 | | | Re: Sway Bars On 03 3.2L Adjustable rear sway bars let you dial in over or understeer. For most folks, it's just more adjustments that they have no idea how to make. The V bars are neutrally balanced already, and sized for more firm cornering (FE4 suspension on a car that weighs 300 lbs more). Most folks have no idea about suspension geometries, instantaneous roll centers, etc. This is why, springs that give too low of ride height are also bad for performance. If you want to dial in your suspension, adjustability is mandatory (sway bars, shock damping and rebound, and spring ride height).
There is such a thing as too stiff, especially if you push hard on a race track. Most folks won't push their cars anywhere near the limit to see how well they're dialed in. I've seen 911's with the inside front wheel 3" off the ground in a hard turn. Way out of adjustment! In that case they need to soften the front (go to mounting holes further out) and stiffen the rear, or to to a smaller bar in front.
04-10-08, 01:46 PM
| | Cadillac Owners Fanatic Cadillac(s): 2004 CTS 3.6 Auto | | Join Date: Feb 2008 Location: Mesa, AZ | | | Re: Sway Bars On 03 3.2L Wow!
Check out the big brain on odysseus. Sounds like somebody has been studying his textbooks. I'm impressed.
Dan |
04-10-08, 09:44 PM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac | | | | | Re: Sway Bars On 03 3.2L Quote:
Originally Posted by odysseus Adjustable rear sway bars let you dial in over or understeer. For most folks, it's just more adjustments that they have no idea how to make. The V bars are neutrally balanced already, and sized for more firm cornering (FE4 suspension on a car that weighs 300 lbs more). Most folks have no idea about suspension geometries, instantaneous roll centers, etc. This is why, springs that give too low of ride height are also bad for performance. If you want to dial in your suspension, adjustability is mandatory (sway bars, shock damping and rebound, and spring ride height).
There is such a thing as too stiff, especially if you push hard on a race track. Most folks won't push their cars anywhere near the limit to see how well they're dialed in. I've seen 911's with the inside front wheel 3" off the ground in a hard turn. Way out of adjustment! In that case they need to soften the front (go to mounting holes further out) and stiffen the rear, or to to a smaller bar in front. | Skip Barber ftw! Any good driving school will probbaly talk about suspension setup. It's really interesting stuff, though Im sure Ody has forgotten more then I know.
Ody, you talk like an engineer, but your name makes me think youre a bit of a Classics nut.  By the way, its spelled "Ulysses"   |
04-11-08, 12:31 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2003 CTS Manual Trans., '93 STS | | Join Date: May 2004 Location: Yorktown, VA Age: 47 | | | Re: Sway Bars On 03 3.2L LOL. Actually, I am (aerospace). I've been a gear head since I was 14, and have modified every car/boat/motorcycle I've owned since then. I try to keep the explanations easily understandable without getting too technical, but sometimes there's no way to not get a little technical (explaining wheel offset with basic math). Explaining instantaneous roll center without pictures is useless. lol |
04-11-08, 12:42 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2003 Cadillac CTS 3.2 | | Join Date: Jan 2007 Location: WI Age: 46 | | | Re: Sway Bars On 03 3.2L Quote:
Originally Posted by concorso By the way, its spelled "Ulysses"   | http://en.wikipedia.org/wiki/Odysseus |
04-11-08, 01:23 PM
|  | Cadillac Owners Master Cadillac(s): 2004 Customized black on tan 3.6L CTS | | Join Date: Oct 2005 Location: Des Moines, Iowa Age: 27 | | | Re: Sway Bars On 03 3.2L Last did you ask me about this also? Did I ever reply? If not, sorry, Im an *******!!   |
04-14-08, 08:49 PM
| | Cadillac Owners Fanatic Cadillac(s): 2003 Cadillac CTS | | | | | Re: Sway Bars On 03 3.2L Quote:
Originally Posted by nickc50310 Last did you ask me about this also? Did I ever reply? If not, sorry, Im an *******!!   | LOL i think i did on another thread....maybe about the struts?
ionno...you probably know enough to help me out here since you've done everythign to ur car already... | | Cadillac Discussion Tools | | |
Censor is ON | | | |
