| Re: Regular vs. Synthetic GM requires synthetic (not necessarily Mobil 1) in the CTS. After you're out of warranty, use what you dare, but until then - here's the direct quote from the manual:
"The engine requires a special engine oil meeting GM Standard GM4718M. Oils meeting this standard may be identified as synthetic, and should also be identified with the American Petroleum Institute Certified for Gasoline Engines starburst symbol. However, not all synthetic API oils with the starburst symbol will meet this GM standard. You should look for and use only an oil that meets GM Standard GM4718M. GM Goodwrench® oil meets all the requirements for your vehicle." |
