Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: HID Ballast location
03-14-08, 10:29 PM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | HID Ballast location So I purchased some HIDs today; lows, highs, and 9005s for the fogs.
Who ever has em, where did you place the ballasts?
Do I have to connect HID Ballasts directly to my battery? or does it use the wires that were connected to the bulbs? If so, where do I find these wires?
It should be a bit of time before they actually arrive at my door (week, tops 2) since I ordered them of vvme and I live in Canada. |
03-15-08, 12:55 AM
|  | Cadillac Owners Enthusiast Cadillac(s): '03 White Diamond Cts | | Join Date: Mar 2008 Location: Tampa, Brandon, Plant City | | | Re: HID Ballast location If your ballest is small enough you could mount it in the stock ballest location (which is located under the headlight I believe)
err...ballAst.
Mine was not small enough to fit, you should be able to find a place to put it. I did not mount mine, they are sitting loose (dont really remember, did my conversion about 2 years ago)
Follow the instructions that come with your conversion kit, you DO NOT wire them to your battery. It is very simple plu g'n'play. You will need to drill a small hole into the back cover of your headlight housing to let the wires through. |
03-15-08, 12:57 AM
|  | Cadillac Owners Enthusiast Cadillac(s): '03 White Diamond Cts | | Join Date: Mar 2008 Location: Tampa, Brandon, Plant City | | | Re: HID Ballast location I only did my low beams so I only had 1 ballast per side, your gonna have to find a place for 2 ballasts per side, since you want to go high beams. Personally, I think you should get your money back and send the high beams back, you will prob. never have to use them again. |
03-15-08, 01:42 AM
| | Cadillac Owners Member Cadillac(s): 06 Red Jewel CTS 3.6 w 6-speed trans | | | | | Re: HID Ballast location You suggest doing the low beams only. What brand/model would you recommend? |
03-15-08, 02:58 AM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | Re: HID Ballast location umm.. no. definatly gonna get it on both. I want it bright, im not the first to get it done on both lows and highs. |
03-15-08, 03:04 AM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | Re: HID Ballast location oh and I dont have stock ballasts since I dont have HIDs, thats why I am getting HIDs. |
03-15-08, 05:31 AM
| | Cadillac Owners Fanatic Cadillac(s): 2003 Cts 3.2 | | | | | Re: HID Ballast location I hope you got some slim ballasts since there's not a lot of room to mount on the headlight.
You're headlight should have an OEM spot for one ballast, even though you don't have HID's. That's the ideal spot to mount, if you can fit it... mine did not fit, but it was not a slim ballast.
From what I remember, there was no way that I could have mounted 2 full size ballasts per side.. unless they were stacked on top of each other maybe.
I probably wouldn't suggest doing that though.. |
03-15-08, 04:51 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 CTS 2.8L | | Join Date: Nov 2006 Location: Westlake, Ohio Age: 25 | | | Re: HID Ballast location You can put a ballast in the stock location which you will see on the headlight and maybe one resting on the metal right behind and under the headlight. There is a small place for a ballast there, but you are going to be short on room I can tell you. |
03-15-08, 06:13 PM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | Re: HID Ballast location the company claims that they have the smallest ballsts so maybe it will work out, I will show pics once I install. |
03-15-08, 06:15 PM
|  | Cadillac Owners Enthusiast Cadillac(s): '03 White Diamond Cts | | Join Date: Mar 2008 Location: Tampa, Brandon, Plant City | | | Re: HID Ballast location cant wait to see 'em. What color temp did you get? |
03-15-08, 06:25 PM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | Re: HID Ballast location all three are 6000k |
03-15-08, 06:32 PM
|  | Cadillac Owners Enthusiast Cadillac(s): '03 White Diamond Cts | | Join Date: Mar 2008 Location: Tampa, Brandon, Plant City | | | Re: HID Ballast location That should look great | | Cadillac Discussion Tools | | |
Censor is ON | | | |
