Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: HELP!!! eibach spring problem real bad squeaking in front end
03-06-08, 11:52 PM
|  | Cadillac Owners Fanatic Cadillac(s): 03cts 3.2 lux/sport navi woodgrain borla dual exhaust/k&n | | Join Date: Dec 2006 Location: los angeles | | | HELP!!! eibach spring problem real bad squeaking in front end I installed eibachs on my 03 cts
the problem is the front end started to squeak when I push up and down on the front of the car or driving over bumps.
does anyone know how I can fix this problem?
thanks
HF |
03-07-08, 09:58 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 CTS 2.8L | | Join Date: Nov 2006 Location: Westlake, Ohio Age: 25 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end I think those might be the shocks? I had some squeaking in the rear when i went over bumps about 2 weeks after I got my Eibach kit installed. It went away, however, and haven't heard it since. |
03-07-08, 10:12 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2007 Cadillac CTS 3.6L Black, LOADED | | Join Date: Apr 2007 Location: Queens, NYC Age: 26 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end I havent done springs on my CTS but i have on other cars. it is normal to hear new springs squeak for a little while |
03-07-08, 10:17 AM
|  | Cadillac Owners Master Cadillac(s): 2004 Customized black on tan 3.6L CTS | | Join Date: Oct 2005 Location: Des Moines, Iowa Age: 27 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end Its hard to say what it is.
I will ask this though- has your car been sitting for an extended period of time without being driven? When my car was getting the damage from my wreck repaired it sat for about a month. When i got it back the front end was squeaking pretty bad. After driving it for about a week it eventually went away. |
03-07-08, 11:51 AM
|  | Cadillac Owners Fanatic Cadillac(s): 03cts 3.2 lux/sport navi woodgrain borla dual exhaust/k&n | | Join Date: Dec 2006 Location: los angeles | | | Re: HELP!!! eibach spring problem real bad squeaking in front end i guys thanks for the responses.
here's the deal, I have had the springs on the car for over a year with no squeaking or any noise whatsoever.
I just had the struts replaced under warranty it's tighter but there is still a squeak. perfectly quiet on smooth roads,but when I hit a bump it makes the sound while bouncing.
could it be the bushing or something?
it sounds like something is being squeezed and released "scrunchy sound".
I hope someone can help me!!!!!!!!! |
03-07-08, 12:39 PM
|  | Cadillac Owners Master Cadillac(s): 2004 Customized black on tan 3.6L CTS | | Join Date: Oct 2005 Location: Des Moines, Iowa Age: 27 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end How long have you had the eibach kit on? |
03-07-08, 01:55 PM
|  | Cadillac Owners Fanatic Cadillac(s): 03 CTS | | Join Date: Oct 2004 Location: Chalk River Age: 32 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end One problem that I found was the plastic shield that goes over the shock. It has a section on there that looks like an accordion. With the lower springs on the car, this plastic part gets stuck on the shock lip, (where the small plunger rod goes into the casing). This causes the plastic to crack in the center of the accordion looking part and makes a "Scrunchy sound". I just took the shock out and trimmed about a inch off the plastic peice so it wouldn't hit the shock. |
03-07-08, 04:43 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2007 Cadillac CTS 3.6L Black, LOADED | | Join Date: Apr 2007 Location: Queens, NYC Age: 26 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end Quote:
Originally Posted by dup's Cadi One problem that I found was the plastic shield that goes over the shock. It has a section on there that looks like an accordion. With the lower springs on the car, this plastic part gets stuck on the shock lip, (where the small plunger rod goes into the casing). This causes the plastic to crack in the center of the accordion looking part and makes a "Scrunchy sound". I just took the shock out and trimmed about a inch off the plastic peice so it wouldn't hit the shock. | I see....... hope it fixes it |
03-07-08, 05:16 PM
|  | Cadillac Owners Master Cadillac(s): 2004 Customized black on tan 3.6L CTS | | Join Date: Oct 2005 Location: Des Moines, Iowa Age: 27 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end My back shocks always squeek when Im beatin up Steveo's chick in the back seat!! Thoughts?  |
03-07-08, 05:43 PM
Originally Posted by nickc50310 My back shocks always squeek when Im beatin up Steveo's chick in the back seat!! Thoughts?  | lol! your shits WEAK! SHITSSS WEAKKK!!  |
03-08-08, 04:25 PM
|  | Cadillac Owners Fanatic Cadillac(s): 03cts 3.2 lux/sport navi woodgrain borla dual exhaust/k&n | | Join Date: Dec 2006 Location: los angeles | | | Re: HELP!!! eibach spring problem real bad squeaking in front end hey Dup did you have to take the shock apart to trim the plastic part?
is this a very hard task to accomplish?
thanks for your input. |
03-08-08, 08:04 PM
|  | Cadillac Owners Fanatic Cadillac(s): 03 CTS | | Join Date: Oct 2004 Location: Chalk River Age: 32 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end You can do with the shock on the car but it wont be very even as you try to get to the back. There isn't much room by the body of the car. Taking it out is easy. 2 Bolts on the bottom and 5 on the top. (under the hood) A little brute and it comes right out. |
03-08-08, 08:05 PM
|  | Cadillac Owners Fanatic Cadillac(s): 03 CTS | | Join Date: Oct 2004 Location: Chalk River Age: 32 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end Oh ya, one more on the upper control arm. |
08-26-09, 05:25 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: HELP!!! eibach spring problem real bad squeaking in front end thanks to all for the info |
08-27-09, 05:01 PM
|  | Cadillac Owners Master Cadillac(s): 2004 Customized black on tan 3.6L CTS | | Join Date: Oct 2005 Location: Des Moines, Iowa Age: 27 | | | Re: HELP!!! eibach spring problem real bad squeaking in front end | | Cadillac Discussion Tools | | |
Censor is ON | | | |
