Does The CTS Suffer From Rusty Rotor Syndrome?
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Does The CTS Suffer From Rusty Rotor Syndrome? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Boy, I saw an 04 rx330 and 04 g35 with the dreaded rust spots forming on the brake rotors. does ...
    Chuck C's Avatar
    Chuck C is offline Cadillac Owners Connoisseur
    Jan 2003
    NE Ohio
    1,531
    Boy, I saw an 04 rx330 and 04 g35 with the dreaded rust spots forming on the brake rotors. does it happen on the CTS too? How can this be prevented? Are stainless steel rotors one answer?
    Slick V's Avatar
    Slick V is offline Cadillac Owners Fanatic
    Apr 2004
    Ft. Lauderdale
    33
    247
    Re: Does The CTS Suffer From Rusty Rotor Syndrome?
    As far as I know all brake rotors get rust after water is on them. As soon as you move the car and then stop once or twice, all the rust is gone. Dont know about stainless rotors.
    strindl is offline Cadillac Owners Fanatic
    Apr 2004
    316
    Quote Originally Posted by Slick V
    You can see those rusty rotors on any car where the wheel gives you a look atnthe rotors..if its been sitting on the dealers lot undriven for a while. As soon as you drive it a bit..the rust is gone. I even noticed it on brand new cars on the dealers lots.
    2004CTSNOV's Avatar
    2004CTSNOV is offline Cadillac Owners Member
    Mar 2004
    Indiana
    33
    18
    Those two people above me allready stole my answer!
    c5 rv's Avatar
    c5 rv is offline Cadillac Owners Connoisseur
    Automobile(s): 91 Allante (gone), 06 SRX (gone)
    Jun 2003
    Michigan
    4,396
    Is it the rotor or the metal brake pad dust on the rotor that rusts?
    RobertCTS's Avatar
    RobertCTS is offline Cadillac Owners 10000+ Posts
    Automobile(s): Black the Darkside
    May 2004
    Central Ohio
    22,418
    Quote Originally Posted by c5 rv
    I think its the calipers that you see rusting. The heat of braking I would say, makes it go away?
    briandors is offline Cadillac Owners Fanatic
    Mar 2003
    41
    164
    Rotors rust, calipers usually don't, they're an alloy. I mean they might get dirty and dark but they aren't oxidizing as a soft steel would "rust".
    The rotor can rust on the swept surface, which will be cleaned when you just drive the car for a bit. Or they can rust at the outside or inside edges. That rust can be slowed down by a special chemical dip, I forget the name off hand. But it only lasts so long.
    I do not believe that true Stainless Steel is appropriate for rotors.
    Brian
  10. Remove Advertisements
