Problem W/ Door lock mechanism? Mines getting stuck..cant close door...
Results 1 to 8 of 8
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Problem W/ Door lock mechanism? Mines getting stuck..cant close door... in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I tried to close my driver side rear door....the locking gear was not grabbing onto the stricker...... I messed with ...
    87vertgt Guest
    I messed with the handle and door locks...still no go......
    Spray Wd40 on that biyatch?
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,316
    Re: Problem W/ Door lock mechanism? Mines getting stuck..cant close door...
    WD-40 will gum it all up. Use silicon spray lube.
    Don't mess with Binky Bear!
    87vertgt Guest
    Quote Originally Posted by dkozloski View Post
    Alrighty will give it a try. Thank you Sir.
    TheGame's Avatar
    TheGame is offline Cadillac Owners Member
    Automobile(s): 07 CTS
    Dec 2007
    Flushing, NY
    39
    19
    I did this once on my other car. I believe I tried pushing up on the door latch and then at the same time pulled up on the door handle. Basically trying to release the door latch and push it back in place. That is assuming it was pushed up in the first place. Or if you are in the northeast with this cold, it is probably frozen. That happened to my Grand prix a few years ago when it was really cold. The lock mechanism froze, so I poured hor water on the door skin by the lock not in between the window or it'll freeze every time. Hope any of those help...Good Luck!
    87vertgt Guest
    Quote Originally Posted by TheGame View Post
    yeah it had to be frozen....it happend on the two nights that it was 4 degrees...and has never happend when it's warm......
    Also....I tried what you mentioned and was positive it would work but didnt......worked on my Tahoe all the time....
    Gonna try the Silicone spray....
    Muhammad's Avatar
    Muhammad is offline Cadillac Owners Fanatic
    Automobile(s): CTS 2005 Sports Luxury 2.8 V6
    Feb 2011
    London, England
    138
    Did you get your problem fixed? I have a similar problem, unfortunately, my passenger door has locked and it is not opening from either inside and outside.
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    196
    I had that problem once on a very cold day (LR door). I tried slamming it a couple times, and that didn't work, so I found that the latch in the door needed to be reset to the open position- just push it up, it clicks into place, and you're ready to go.
    Jhayzhone's Avatar
    Jhayzhone is offline Cadillac Owners Member
    Automobile(s): Custom 2007 cts
    Jan 2012
    Canada
    74
    I had the same problem today. Im trying to close my LR door and it looks like the door latch is frozen, probably because i had my car washed this morning and it was not dry properly then parked it outside with -38 temperature!.
  11. Remove Advertisements
