04 CTS 3.6 Oil Change ? (drain plug)
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 04 CTS 3.6 Oil Change ? (drain plug) in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello, I have a 2004 CTS with the 3.6L engine. We are going to change the oil in it and ...
    dziegiel is offline Cadillac Owners Member
    May 2004
    3
    Hello,
    I have a 2004 CTS with the 3.6L engine. We are going to change the oil in it and found the oil filter with no problem, but the drain plug is another issue. We wanted to know if anyone can ID (either by picture or good description) where it is. Also what tool is need to unsrew it (size). Also to confirm, the oil filter uses a 15/16" socket to get it off.
    Thanks in advance,
    Jason
    86caddtwithflows is offline Cadillac Owners Member
    May 2004
    51
    Re: 04 CTS 3.6 Oil Change ? (drain plug)
    uhh if u cant find the drain plug u best just take it and pay to get it done...i do so many it is hard to remember whether it has a skid plate or not but it isnt gonna be hidden
    May 2004
    3
    We found it. Its a 13mm socket that was required. We wanted to confirm that it drained to the right and not the bottom and that we were not blind.
    Jason
