Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: 2005 CTS Oil consumption
12-11-07, 12:15 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | 2005 CTS Oil consumption anyone having trouble with oil consumption. I have 37,000 miles. I currently have 15% oil life remaining before my next oil change. I've already added 4 quarts of oil. I have no leaks. Dealer tells me this is "normal". I can't believe it. |
12-11-07, 01:01 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Jul 2007 Location: belleville, nj Age: 38 | | | Re: 2005 CTS Oil consumption Wow that dont seem right? I dont know much about car problems my self but that is very low. I know i have 4700m on mine with 47% oil left and im not due for a change until 7000. I hope i dont get that low before hand. |
12-11-07, 01:13 PM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS | | Join Date: May 2007 Location: Connecticut | | | Re: 2005 CTS Oil consumption Keep an eye on it. My 04 CTS 3.6 usually drinks an extra 2 quarts between changes; and I change mine every 5000 miles. Dealer said the same thing "normal" |
12-12-07, 10:08 AM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS - 2005 | | Join Date: Feb 2007 Location: Edenton, North Carolina | | | Re: 2005 CTS Oil consumption I have an '05 with 34000 on it, and it doesn't drink a drop of oil. Your dealer's full of crap. |
12-12-07, 11:37 AM
| | Cadillac Owners Connoisseur Cadillac(s): Sedan de Ville, CTS | | Join Date: Mar 2007 Location: San Antonio, Tx | | | Re: 2005 CTS Oil consumption My 04 3.6 does not use any oil. Print these out and show to service mgr. Also, ask for (GM) regional guy to get his input. |
12-12-07, 01:29 PM
| | Cadillac Owners Fanatic Cadillac(s): 2008 CTS DI | | Join Date: Jan 2005 Age: 47 | | | Re: 2005 CTS Oil consumption My 3.6l with 50K miles used about a quart every 7500 miles. |
12-12-07, 01:46 PM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac | | | | | Re: 2005 CTS Oil consumption 2006 3.6L, 30K...I check every gas fill-up, and it has never burned oil.
Dealer is bs'in for some reason... |
12-12-07, 08:05 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2009 CTS4 Blue Diamond | | Join Date: May 2005 Location: Michigan-Lake Superior | | | Re: 2005 CTS Oil consumption My 2005 has 22,000 miles and has never used any oil. I change it once a year at approximately 7,500 miles which has never been less the 40% life remaining. I use Amsoil 0W-30 and the oil level never moves. Are you using synthetic oil?
Which brand?
Some brands of oil will burn off (volatility) worse then others, try changing to another at next change to see if it improves.
12-12-07, 09:41 PM
|  | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Jul 2007 Location: Calgary, AB | | | Re: 2005 CTS Oil consumption I have an '07 3.6 with 21,000 kms. Have changed the oil every 5000kms since new and have had to add at least 1 litre of oil between changes. My dealer also says this is not excessive. Waiting on the GM service rep to respond. Keep you posted. |
12-13-07, 04:34 PM
|  | Cadillac Owners Connoisseur Cadillac(s): Check out my CTS here: http://www.fquick.com/FL01SS | | Join Date: Oct 2006 Location: Just moved to Williamsburg, VA Age: 29 | | | Re: 2005 CTS Oil consumption 1/2 a quart every 7500 miles on my 04 3.6 with 46k miles. |
12-13-07, 09:45 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2000 STS, Past : 99 STS, 94 STS | | Join Date: Aug 2004 Age: 30 | | | Re: 2005 CTS Oil consumption It has to do with the rings as they get dirtier. The Northstar is notorious for oil burning it is normal. But there are things you can do to avoid it.
1. Give your car some wide open throttle runs to clear the carbon buildup off the rings.
2. Take it to your mechanic and have them clean out the upper engine. (Not the fun way and it costs money)
3. CHANGE YOUR OIL MORE OFTEN. The sensor is for normal driving and on the gm website it says if you are in alot of stop and go driving you should still change your oil every 3000 miles or in dusty conditions. |
12-14-07, 11:09 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS | | Join Date: Dec 2006 Location: Olmsted Falls, OH Age: 25 | | | Re: 2005 CTS Oil consumption mine drank a bunch too....
so much that i spun a rod bearing and got a new motor at 50k |
12-15-07, 11:52 PM
| | Cadillac Owners Member | | | | | Re: 2005 CTS Oil consumption Ditto for that here fire. Mine spun the #3 rod bearing at 57K miles and Cadillac bought me a new crate motor. Search the forum for the story and the details. |
12-23-07, 12:27 PM
| | Cadillac Owners Fanatic Cadillac(s): 2008 CTS Radiant Bronze, Performance Collection RWD | | Join Date: Jan 2006 Location: Wayne, MI Age: 56 | | | Re: 2005 CTS Oil consumption My 04 CTS 3.6 has 81000 miles on it and change the oil every 6000 miles. I am adding a quart of Mobil 1 at 3000 miles and was down a quart when I changed it recently. I know that FoMoCo claims that a quart every 1000 is considered "normal". (No Ford for me) |
12-24-07, 01:37 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac CTS | | Join Date: Dec 2006 Location: Olmsted Falls, OH Age: 25 | | | Re: 2005 CTS Oil consumption yeah the dealer tried to tell me that it was my fault for not checking the oil... I had been right at the 3 k mark and they said i only had a quart left... no low oil indicator or anything..
they tried to talk me out of having them tear the bottom half out and have a gm rep come out because they said my warr. claim would "probably" be denied...
Guess who's car has a new motor??
Stupid dealer.... GM said replace it, no questions asked | | Cadillac Discussion Tools | | |
Censor is ON | | | |
