I bought both of my rears off of Ebay. Two different vendors; about the same price. Great customer service from both.
You need to go to the parts store and get a door panel remover. LISLE makes a GREAT one. It has a red handle and looks like a weird screwdriver.
Have an able bodied assistant that is good with their hands.
You will also need some BLUE painters tape to hold the glass in place once you remove the regulator.
The trim piece behind the door handle release just pops off, but be careful. You need to push down on the top and up on the bottom to get it to release.
There is a bolt cover behind the door pull handle.
You might need to pull the inside and outside weatherstrip that around the top of the door off.
The door lock cover is kinda a booger to remove, but if you have a very small flat blade scredriver then it comes right off.
Be carefull as you take the door panel off, you will need to pull the door panel back a little to locate the clips that hold it on and to stick in the door panel remover tool.
Once you get the door panel off, you will have to remove a small module.
Then you need to take the vapor barrier off. Grab a corner and pull briskly so as to remove all of the black goo on to the vapor barrier itsel instead of the door.
Tape the window back to itself.
Start removing the bolts and the regulator will come out.
Repeat process in reverse order.
I am sure I have missed some very minor steps, but that is about it.
PM me if you need help.
Repair at your own risk!
