Originally Posted by afterdigital could you tell me how you were able to remove the chrome pillars? what you did wrong? and what tips to make for a better removal?
thanks
anonymous  LOL |
I used a flat-head screwdriver to pry up the corners then grabbed the pillar with pliers and pulled. I only had a hairdryer to heat it, and I don't think it was hot enough. One of them stuck half way down and I couldn't get it to pull off so I used the screwdriver to get past the stuck point. Apparently I wasn't gentle enough and nicked the paint in a few places, but it came off.
If I had it to do again I would have pried up the corner with the screwdriver carefully, pulled a little bit at a time and while using a hotter heat gun to heat it as I pulled. No screwdriver after the first corner.
