CTS lug pattern
Results 1 to 15 of 15
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, CTS lug pattern in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; What is the lug pattern for the cts? also I want to get 20" rims for my car and I ...
    dtg1109 is offline Cadillac Owners Member
    Apr 2004
    1
    CTS lug pattern
    What is the lug pattern for the cts? also I want to get 20" rims for my car and I wanted to knwo which wheels are the best for this car
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: CTS lug pattern
    5x115...
    Neoflex is offline Cadillac Owners Fanatic
    Oct 2003
    NY NY
    41
    164
    Re: CTS lug pattern
    Finding 5 x 115s is tough but 5 x 114.3 will work with a hub centric ring. Also make aure the offset is atleast +35 and make sure not to exceed 20 x 8s otherwide you will have major rubbing issues.
    jsw029 is offline Cadillac Owners Member
    Mar 2004
    46
    Re: CTS lug pattern
    I'm looking into 18" rims for my '04 CTS. The rims I'm looking at are 18 x 8.5 and the tires would be 245/40/18 or 245/45/18 (most likely Goodyear Eagle F1).
    Does anyone know if I would have any problems with my brakes, speedometer, mileage, rubbing, etc.?
    Thanks,
    jsw029
    briandors is offline Cadillac Owners Fanatic
    Mar 2003
    41
    164
    Re: CTS lug pattern
    This calculator will answer your speedometer question, and partly answer the rubbing question.
    http://www.miata.net/garage/tirecalc.html
    If you keep the overall diameter close, then you just need to get under your car and look to see if the tire can grow 1cm on each side,,, or whatever amount you want to widen. Be sure to look up into the wheel well too.
    The other thing to do is ask people who have already experimented with how wide you can go. Bueller?
    Brian
    Mar 2004
    46
    Re: CTS lug pattern
    Thanks Brian, that website is very helpful. I'm going to start a new thread regarding the width.
    Thanks,
    jsw029
    smuook's Avatar
    smuook is offline Cadillac Owners Member
    Mar 2004
    Florida
    71
    Re: CTS lug pattern
    Quote Originally Posted by jsw029
    Thanks,
    jsw029
    I have a CTS luxury with 18x8.5 rims and 245/50/18 Falken ZE512 tire's... The tire fit in the wheel well is perfect. There is no rubbing at all. The overall wheel diameter is very close to factory (about 26 if I rember right) so the speedometer is right on.
    I didn't have some vibration at about 70 mph... I had the balance re-checked and it's perfect. The lug pattern is 115mm on the new wheel (vice 114.3) so I think that the center is not perfect. I'm looking for a hub centering adapter to get the center right on... anybody had this problem?
    miscreant's Avatar
    miscreant is offline GM Connection
    Feb 2004
    Norman, OK
    44
    1,286
    Re: CTS lug pattern
    Quote Originally Posted by smuook
    I think you mean 245/40 or 245/45R18 for your tires. And I think you mean that the lug pattern on the new wheel is 114.3 versus the facotry 5x115.
    And yes, you need hubcentric rings to curb that vibration. You'll need to contact your wheel manufacturer to find out what size the hub hole is on your wheel. The cTS has a 70.30mm hub, so you'll need this number plus the number you get from your manufacturer to find the right ring.
    What wheels do you have?
    2004 Cadillac CTS (**SOLD** ): http://www.ctsowners.com
    2004 Pontiac GTO: http://www.myyellowgto.com
    smuook's Avatar
    Mar 2004
    Florida
    71
    Re: CTS lug pattern
    Oopps.. 245/40 (typo).
    Thanks for the info miscreant...
    I have Giovanna Barbados I rims... http://www.giovannawheels.com/giovanna3/cardetails/barbados1D.jpg
    They are triple chrome plated with a nice fat lip... I love the way they look. I've gotten many "Wow!" comments from them. They give the car a very unique look. I have them off right now but I'll post some pics when I get them back on (when I get the hubcentric rings).
    The 18's don't really cause a harsh ride either... I think they really "fit" my car... a good compromise between style and ride quality.
    Mar 2004
    46
    Re: CTS lug pattern
    I've just about decided on getting 18 x 8.5 Gianelle 10 Flush rims
    (5 x 114.3, +35 offset) for my '04 CTS with the Luxury Sport package. Does anyone see any problems with this?
    The tires I'd like are 245/40/18 Goodyear Eagle F1 but I may opt for less expensive Falken FK451 tires (they seem decent but I'm not sure).
    Any opinions/suggestions would be appreciated.
    miscreant's Avatar
    Feb 2004
    Norman, OK
    44
    1,286
    Re: CTS lug pattern
    The only "possible" problem I see is that the wheels/tires will stick out slightly past the fender in the front. The V wheels are 8.5" wide and 42mm offset, so a 35mm offset will stick out 7mm more. The V wheels fit pretty flush already. That would be my only concern - were they 8" wide, I don't think you'd have a problem.
    eljefe7070's Avatar
    eljefe7070 is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade
    Apr 2013
    Virginia Beach, VA
    36
    3
    Re: CTS lug pattern
    Smuook can you post pics of the set up?
    HawkzillaCTS is offline Cadillac Owners Member
    Automobile(s): 2006 CTS 3.6L
    Oct 2013
    Iowa
    60
    Re: CTS lug pattern
    I just put some 19s on last week. Tires are 245/35ZR19 8.5 Sumitomo HTR Z III (I did a lot of research on the tires and couldn't recommend them more, for summer tires anyway). Anyway, while I love the look of my wheels I wish I would have researched that part more. Mine are 33 lbs each and while I like the added durability, I can feel a slight power loss and have noticed a 2 mpg loss overall.
    My advice for you is to research your wheels well and try to find the lightest 20s you can (assuming they are still durable). Also, like another guy said, don't go under 35 on the tires.
    Good luck!
    Attachment 198313
    Attachment 198321
    Attachment 198329
  16. #14
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,540
    Re: CTS lug pattern
    Quote Originally Posted by eljefe7070 View Post
    Holy 10 year thread bump, Batman! smuook hasn't been active in over 4 years according to his profile, so I'm guessing the answer is NO.
    Quote Originally Posted by HawkzillaCTS View Post
    Nice looking wheels, but yeah, 33# is a heavy damn wheel!
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  17. #15
    JMontrealC is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac CTS
    Mar 2014
    Atlanta, GA
    28
    11
    Re: CTS lug pattern
    I'm looking at doing 20s myself... have any of you ever bought rims off of eBay?
  18. Remove Advertisements
