CTS Subwoofer Upgrade
Results 1 to 11 of 11
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, CTS Subwoofer Upgrade in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I am thinking about upgrading the stock subwoofer in my CTS (non-Bose system). Before I start taking things apart to ...
    Justin83NJ is offline Cadillac Owners Member
    Feb 2003
    New Jersey, USA
    32
    34
    Before I start taking things apart to find out for myself, I figured I'd ask you guys a few questions.
    - What size is the stock subwoofer -- 8" or 10"?
    - How do I replace it? Do I have to take the rear deck/rear seats out or can it be removed from underneath in the trunk?
    - Where would be the best place to add a stronger subwoofer amp so it is out of sight? What does the stock setup consist of?
    - Would I have to run a new, thicker power wire to a new amp (200-400 W RMS) or is the existing wiring sufficient?
    BUILDINGCTSAMG is offline Cadillac Owners Connoisseur
    Mar 2003
    Atlanta Ga/Mclean Va
    31
    1,754
    I dont know all these cause im having a shop do this for free in addition to the rest of my stuff
    but its a 10"
    im pretty sure it need the deck taken off, but u might be able to squeeze it in, ill tell u when it get done. The sub you can put on the underside of the rear deck and it wont show at all
    if your using a bigger sub a bigger wire is better
    letsgored is offline Cadillac Owners Member
    Mar 2003
    12
    B'CTSAMG, I'd love to hear any and all details that you find out about the base CTS speakers and appropriate upgrade specifications (speakers sizes/depths, appropriate ohms, etc.).
    I'm not very versed in this stuff, so someone please correct me if I'm wrong, but if you're planning on replacing the CTS's rear deck subwoofer, you should look for a replacement that is designed as "open air". Most subwoofers aren't; they are designed to be put into a small box/enclosure to sound right. With an "open air" subwoofer, the entire trunk area acts as the enclosure. Since I can see the bottom of the CTS's subwoofer when I look in my trunk, I would say that this is an instance where an "open air" designed replacement is most appropriate.
  5. #4
    Mar 2003
    31
    1,754
    Yeah this is defn open air, butyou can build a box. I just didnt want to waster trunk space
  6. #5
    Feb 2003
    New Jersey, USA
    32
    34
    Yes, I'm planning on using an open air subwoofer. But I wasn't even sure what size the sub was. Now that I know it is 10 inch, I will probably go with the Inifinity Kappy Perfect 10 VQ, and a Rockford Fosgate amp.
    I am going to start taking things apart this weekend to see where the stock sub gets its signal -- from an amp concealed in the trunk or from up front.
  7. #6
    Mar 2003
    31
    1,754
    Yeah, unfortunatly my car is in the shop in dc and im taking exams in atlanta (Go Emory!) So i cant tell you everything about the install. (I will be able to give way more info by next weekend) anyway, im getting a kicker open air put in (you should look at kicker its a pretty good company) and spend the extra money on fosgate, they have the best high end stuff and some of the crappiest low end stuff. Good company overall, made in the dessert of arizona so they can sound test all their stuff.
  8. #7
    Mar 2003
    12
    B'CTSAMG, how'd the install go? I'm interested in hearing any details you can share.
  9. #8
    Mar 2003
    31
    1,754
    It hasnt started yet! My brother got a new car that is the install places show car (all fosgate utopia stuff super expensive!!) so right now his car is completely gutted and i have to wait for them to finish! I may not go with the open air afterall though...we'll see!
  10. #9
    Feb 2003
    New Jersey, USA
    32
    34
    I haven't done anything with the stereo yet, either. I had been too busy with school, now I'm too busy with work.
    But thanks for the info, AMG! It's funny you mentioned Kicker because I had been looking into a Kicker sub too -- same power and sensitivity ratings as the Infinity Kappa and much cheaper.
    Good luck with your install and keep us informed!
    Justin
  11. #10
    homer403 is offline Cadillac Owners Enthusiast
    Dec 2004
    McLean, VA
    50
    705
    Re: CTS Subwoofer Upgrade
    BUILDINGCTSAMG... did you do it yet??? I am getting sick of my weak sub... I really want to drop in another sub but am hearing the same "open air" vs "box sub". Did you ever find the ohm rating for our sub?
  12. #11
    rigo is offline Cadillac Owners Member
    Automobile(s): cadillac cts 2003
    Apr 2015
    Aruba
    52
    I up grade my sub woofer of a cadillac cts 2003 but now i have no more sound coming out, i do know the original is a dual but i install a single one, well now i found out, whats the cause and the damage by doning so or to make me lose power on the sub
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
