Originally Posted by MPS I tried to leave the battery disconnected for a longer period (45 min) and the only thing that got reset was the clock.
Also if it's not on parking the safety interlock message appears and on the right corner it shows what to do : turning the knob to search and using the seek button to seek exactly like on the radio but on the radio it also shows to push the knob for the radio menu and i think it should be the same for the tv.
Please help me because i don't have a real cadillac dealer here, well it is one but just dealer it doesn't have a service and the closest one is 800 km away in Budapest, Hungary.
Thank you |
First you need to be sure you selected the tv function from the main menu. Then, indeed, when you push the turning knob you get a menu. The top side button you can select the aux in when it is in tv mode, or vice versa. When it is in tv mode and you are in park, you should at least get static on your screen. You can search up and down the frequency band, just like with the radio. I hope you have analog tv broadcasting there? Because digital it won't pick up.
I can't think of anything if it doesn't work nor reset.
Thanks for all the props!
