Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS First Generation Forum - 2003 - 2007
Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: Drive Shaft..
  #16 (permalink)
Old 11-20-07, 02:29 PM
TQDrivenWS6's Avatar
Cadillac(s): 2005 Red Line 3.6L lux/sport
View TQDrivenWS6's Photo Album
Casino Cash: $592
Re: Drive Shaft..
I would have to see a picture of the rubber piece in question, but the C5's torque tube / driveshaft type thing has an individual piece like this that can be ordered from GM. The part number is even cast into the piece so if you can DIY you may be able to source the part.
  #17 (permalink)
Old 11-20-07, 04:41 PM
jkh jkh is offline
Cadillac(s): 2005 CTS Raven Black
View jkh's Photo Album
Casino Cash: $1547
Re: Drive Shaft..
[quote=wait4me6920;1250316]Keep a close eye on it - many owners, self included, have had differential problems. Symptoms most commonly are a moaning, rumbling or whining from the rear - often most noticeable at 30 - 50 mph under light or trailing throttle...
I had the rumbling at low speeds and coming to a stop. I thought it was the tires...turned out the pinion seals on the diff were loose and I had lost most of the diff fluid. They tightened the seals, put more fluid in, and the rumbling went away. Now...what damage will that cause in the future....
  #18 (permalink)
Old 11-20-07, 06:38 PM
Spyke's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2005 Cadillac CTS 3.6L VVT
View Spyke's Photo Album
Casino Cash: $16748
Re: Drive Shaft..
Originally Posted by mkboyd View Post
The symptoms are a vibration when not under load above about 30 mph. Under load, either accelerating or deceleration, no vibration (or very minor)..
mine is a 05 with 62k miles and does that problem. But it vibrates only when I press slowly the gas for example at 70km/h and the car doesn't downshift.. if I stay steady it doesn't vibrate at all, if the car downshift, no problem at all.. but if you ask power and the transmission doesn't go down one gear, it shake.. should I worry?
Tags: ,
drive, shaft
