Results 1 to 4 of 4
Thread: CTS-V (2nd gen) Polished Aluminum Sedan Wheels + Tires $1400
    00blueYZF is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2007
    Metro Detroit
    51
    For sale: Set of 19 polished aluminum CTS-V sedan wheels.
    $1400 local pick-up only - Located in the Flint, MI area
    There is a lot of tread left (50%+) on the original Michelin Pilot Sport PS2 tires
    I had these on my 2008 V6 RWD sedan since they were nearly new. There is a small spot of rash on one front wheel and some barely noticeable stone chips on the other front wheel. One rear tire has a professionally installed patch in the tread. These look awesome on the base CTS. Or you can use these wheels as a set of spares for winter or put on a pair of dedicated drag tires.
    The TPMS and black Cadillac center caps are included. No lugnuts included
    Specs:
    5x120 bolt pattern
    Front: 9.0x19 :: 255/40 ZR 19 (96Y) Michelin Pilot Sport PS2 tires :: 51mm offset :: 66.9 mm bore
    Rear: 9.5x19 :: 285/35 ZR 19 (99Y) Michelin Pilot Sport PS2 tires :: 56mm offset :: 66.9 mm bore
    Other vehicles these may fit:
    2008-2013 CTS and CTS-V Sedan and Wagon (245/45-19[fr] and 275/40/19[rr] tires recommended for AWD to prevent rubbing)
    Pontiac G8 (can add front 3mm spacer in front for lowered cars)
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    A lot of G8s running these...
    Tsirpas is offline Cadillac Owners Member
    Automobile(s): 2008 CTS 3.6L AWD
    May 2012
    Toronto, Ontario
    27
    9
    Amazing price! Wow, bought mine for 2400 same tread.... Somebody should jump on this!
  5. #4
    Jul 2007
    Metro Detroit
    51
    Re: CTS-V (2nd gen) Polished Aluminum Sedan Wheels + Tires $1400
    These are now sold. Thanks for the interest
  • You may not post replies
