cleaning the breathers!?
Results 1 to 12 of 12
Cadillac Catera and Cimarron Forum Discussion, cleaning the breathers!? in Past Cadillac Vehicle Discussion; I have been reading alot on the Omega forums, just because they have had these cars longer than us and ...
    dpligocki's Avatar
    dpligocki is offline Cadillac Owners Member
    Automobile(s): 2001 Catera Sport
    Apr 2004
    37
    Talkingcleaning the breathers!?
    I have been reading alot on the Omega forums, just because they have had these cars longer than us and they are in much more abundance over in europe...
    They like them over there, they constantly say if they are maintained right they will go forever and most of them have around 16ok miles now...
    I do believe this especially for the 2000 and 2001s.
    Anyways, they were saying that a key step is cleaning the breather system from time to time and this will prevent (most likely) overpressurization and blowing the valve cover gaskets...
    I have 30K miles on my 2001 now and I want to clean them... Has anyone done this in North America? I could not find anything in this forum about it!
    Thanks for any help!
    David!
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Re: cleaning the breathers!?
    I asked the same question on the Omega Owners Forum and got this explaination. They also have the procedure in their Maintenance Guide section.
    See the black plastic bit on middle of plenum - it has a logo on it? This is a thin cover, flick off (just the cover, not the whole plastic bit, to reveal a screw. Remove this screw, and the 2 you can see on the plastic leading to throttle body. Mark and remove the 4 rubber pipes at back of this plastic bit, then remove the plastic bit and thoroughly clean in with carb cleaner.
    Those 4 pipes you removed? The 2 outside ones join and go off to a 'breather box' behind left bank (looking from front) - passenger side for you boys who drive on wrong side Wink. Remove this rubber pipe, and clean with carb cleaner.
    One of the little rubber pipes also goes to this breather box, clean this as well. Where it enters breather box, there is a tiny hole. Make sure this is clear - but don't insert a pin too far.
    Remove the throttle bodies, and clean with carb cleaner.
    Refit is reverse method, renewing any gaskets that are past their best.
    Follow the link to their Maintenamce Guide:
    http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
    Elvin
    rinverso is offline Cadillac Owners Fanatic
    Automobile(s): 2001 catera
    Feb 2007
    west palm beach fl.
    58
    211
    Thumbs upRe: cleaning the breathers!?
    elvin, thanks for the omega owners forum link, thats awesome. i feel like a real newbie. oh yeah, i am.
    thanks again, robert
    dpligocki's Avatar
    Apr 2004
    37
    thanks for the link!
    I have been looking for that guide for a long time, I read it is the one to use!
    I am going to get my mechanic to do it this spring!
    it says every 12 mths but i think i will do it every 3 years because I only drive the car in the summer about 6k miles per year!
    Thanks again!
    dpligocki's Avatar
    Apr 2004
    37
    Thanks again!
    newbee is offline Cadillac Owners Member
    Automobile(s): 97 Catera
    May 2005
    colorado
    28
    57
    Quote Originally Posted by elvin315 View Post
    Elvin
    thanks for the link
    Marks DTM Calib is offline Cadillac Owners Fanatic
    Automobile(s): Vaux Omega (Caterra)
    Dec 2006
    Nottingham - England
    235
    We plan to add pics to the process this weekend.....
    I have to also say that generaly we find the Omega reliable from about 1995 onwards.....there were no major changes in 2000/2001 other than styling tweaks....
    dpligocki's Avatar
    Apr 2004
    37
    I like this how-to very detailed and will help!
    My only question is: I always thought the plenum had to be removed... but in the how-to i dont think it mentions removing the plenum... is it just implied that it should be done? and if so is this a big job to remove the plenum or not so much?
    Thanks again!
    Dec 2006
    235
    Its easier with it removed as it can all be put on the bench and worked on....it can be done without removal though..
    Plenum is reasonably easy to remove.
    Disconnect the throttle cable (1 small locking clip and rubber bung into the throttle cable mount))
    Disconnect cruise actuator cable (a further clip and cable is mounted using a set of plastic tabs that need to be pressed in to release).
    Idle valve wiring and feed pipe need disconnecting
    EGR feed pipe and mounting bracket bolt need removing (if fitted)
    Inlet trunking jubilee clips need slackening and pipes popping off the throttle bodies
    Remove the 4 bolt cover caps and slacken and remove the plenum bolts
    Disconnect the brake servo vac pipe
    Lift plenum up off locating dowels and ease forward so you can disconnect the rear multiram vac feed and wiring.
    That should be it....there might be some additional bits on a Cat to meet local emission laws...
    dpligocki's Avatar
    Apr 2004
    37
    this is excellent help! thanks
    what do you reccommend, Removing the plenum or not?
    Dave,
    Dec 2006
    235
    I always remove it....its so much easier to clean the bits in the kitchen sink when 'she who must be obeyed' is out...
    dpligocki's Avatar
    Apr 2004
    37
    I'm going to have my mechanic remove it... I will help him, but neither of us have done this before. How long do you think it will take? Is it an easy job for a gm mechanic even tho he has never worked on a Catera before or should I bring it to someone who has worked on a catera before?
  15. Remove Advertisements
