Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: A simple test and easy fix...
Old 02-19-07, 03:55 AM
Marks DTM Calib Marks DTM Calib is offline
Cadillac(s): Vaux Omega (Caterra)
View Marks DTM Calib's Photo Album
Casino Cash: $250
Ok, as promised here is number one of my weekly series of little tests and tweaks to do to your car to keep it running nicely.
This first one came about after seeing a number of higher mileage cars where the inlet multiram system was not working optimumly. This could be felt particularly at sub 4000rpm with heavy throttle (i.e. overtaking!).
For those interested, here are some extracts from the Vauxhall college training programme notes which give some details of how the multiram works...:
V6 Multiram Operation
The multiram actuators are vaccum operated and its essential that this vaccum supply is good and consistent....this is the idea of this little test and fix!
For all those with a later (post 96/97) V6 which has the additional VAC tank mounted on the set of trumpets just in front of the alternator.
Here is something to try.....
The vac tank has two pipes, a feed and an output, the fed is the one on the right or bottom (or at least should be) which connects to a large rubber elbow piece.......
Here is the test I would like you to try.....
Follow the pipe from the vac tank feed to the rear of the engine bay where it connects to the brake servo pipe (normally via a T piece).
Disconnect the pipe here and suck on it, place your tongue over the pipe and check it holds vaccum.......
Reconnect the pipe and now remove the output from the vac tank (you can do this at the front multiram solenoid if its easier).....does it hiss for a short period or not?
If it does hiss all is good, if not, then read on!
The vac tank has a one way valve on the input so that when on Wide Open Throttle (WOT) the vac reserve is maintained (there is very little manifold vaccum at WOT), This valve sometimes fails and the above procedure tests it......
The fix is easy......take a trip to your local aquatics store that sells items for indoor aquariums and ask for an air valve (the type placed in the air feed pipe from the air pump to stop syphoning if the pump fails).
Place this in the feed to the multiram vac tank and repeat the test.....it should now hiss....if it doesn't then you might have fitted the valve the wrong way round so try reversing it.
Once done, enjoy the perkier engine response (much more noticeable on stick shifts).............
  #2 (permalink)
Old 02-19-07, 02:36 PM
frank moran frank moran is offline
Cadillac(s): Catera, ..
View frank moran's Photo Album
Casino Cash: $7556
Re: A simple test and easy fix...
very good information, especially knowing there is a check valve in the reserve tank.... good job.
  #3 (permalink)
Old 02-20-07, 11:22 PM
rinverso rinverso is offline
Cadillac(s): 2001 catera
View rinverso's Photo Album
Casino Cash: $649
Thumbs up Re: A simple test and easy fix...
ill give it a try this weekend!
thanks a bunch, robert
Tags: , , ,
easy, fix, simple, test
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
