Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: When the timing belt goes...
Old 02-17-07, 08:27 PM
97catera18 97catera18 is offline
Cadillac(s): Cadillac
View 97catera18's Photo Album
Casino Cash: $285
What all gets destroyed when the timing belt is off or breaks? For a 97 cat that is.. Any help would be greatly appreciated!!
-E
  #2 (permalink)
Old 02-17-07, 08:53 PM
german_catera_fan german_catera_fan is offline
View german_catera_fan's Photo Album
Casino Cash: $250
Re: When the timing belt goes...
hi there, that depends on the rpm that your engine was running at when the belt died.
if it was really slow then you might be lucky and will just have to replace a few valves and hydraulic valvelifters.
if the revs where a little higher, you can be sure, that all24 valves/hydraulic valvelifters are done. AND the pistons are in 90 % of the cases junk as well. because the edges get bent during the "headcrash" and the pistonrings are not gonna be able to move anymore.
been there, done it.
broken belt=refurbish engine! belive me
and if you REALLY have bad luck, the valve stem guides have cracks as well, which means: replace either the guides or the the heads......
  #3 (permalink)
Old 02-18-07, 02:04 PM
Casino Cash: $285
Thanks for the info. The RPM's where kinda high. I'm was wondering what im getting into here. What should I all replace on this motor? I have a good motor with higher miles that Im gonna use as a parts motor for it. I dont want to hange the motors I just want to swap the heads and such..What all should I use from my good motor to put on the bad motor to fix it?
Thanks!!
-E
  #4 (permalink)
Old 02-19-07, 03:39 AM
Marks DTM Calib Marks DTM Calib is offline
Cadillac(s): Vaux Omega (Caterra)
View Marks DTM Calib's Photo Album
Casino Cash: $250
How many teeth did the belt jump, if only 2 or 3 then the valves just get nicked and bent open slightly, this does little or no damage to the pistons and the bottom end is still good........
If you plan to re-use the heads then you need all the valves out and inspect the valve guides very closely with a bright light and magnifier....
  #5 (permalink)
Old 02-19-07, 10:28 AM
frank moran frank moran is offline
Cadillac(s): Catera, ..
View frank moran's Photo Album
Casino Cash: $7556
That was the exact condition of mine when I bought it, 6 bent, 3I and 3X, nothing else damaged...the middle ider came apart, the belt jumped and thus the damage.....
  #6 (permalink)
Old 02-19-07, 11:10 AM
LV2FLY's Avatar
LV2FLY LV2FLY is offline
Cadillac(s): 96 STS
View LV2FLY's Photo Album
Casino Cash: $250
Question: When should a timming belt be replaced:
A) if you do not know the history?
B) every how many miles or years?
  #7 (permalink)
Old 02-19-07, 11:55 AM
Casino Cash: $250
Answer
A) Staright away
B) 40K miles or 4 years
And you repalce the belt, idlers and tesnioer as its not actualy the belt that fails.....worth doing the water pump at the same time as well....
  #8 (permalink)
Old 02-20-07, 03:43 PM
LV2FLY's Avatar
Cadillac(s): 96 STS
Casino Cash: $250
Roger that!
Tags: , ,
belt, timing
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
