Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: head replacement
Old 02-09-07, 11:00 PM
97catera18 97catera18 is offline
Cadillac(s): Cadillac
View 97catera18's Photo Album
Casino Cash: $285
Exclamation head replacement
what would be easier to do? replacing a few bent valves and the cylinder heads..or just changing the whole motor? this is for a 97 cat. I have a motor with high miles that runs great...And I have a motor with really low miles that the timing belt went on. Could I Use the parts from my cat that has high miles on the motor with low miles?? Thanks for the help..!!
-E
  #2 (permalink)
Old 02-12-07, 03:52 AM
Marks DTM Calib Marks DTM Calib is offline
Cadillac(s): Vaux Omega (Caterra)
View Marks DTM Calib's Photo Album
Casino Cash: $250
Re: head replacement
I would say yes.....I have changed a few heads (following cambelt failure wen peopel dont follow the 40K 4 year rule!)
It normlay costs me about £220 all in with a new timing belt...
I would take the good heads and strip them, clean the valves up (put them in a drill and use some wet and dry with some soapy water, dont touch the seats), fit new stem seals and clean the heads up well before re-build (note, paint stripped is brilliant at removing carbon and oil staining).
You need to use the T vents off the replacement engine (two per head, torx headed) as they must match the oil pump (it changed in around 98 to a higher pressure variant).
Also worth cleaning the followers, see here for how to:
Cleaning and checking a follower
That way you are fitting an excellent set of heads.....to a known good block...
Re-seal the oil cooler plate whilst there and use the same sealent around the stat housing (or fit the later modified setup)
  #3 (permalink)
Old 02-12-07, 11:52 AM
frank moran frank moran is offline
Cadillac(s): Catera, ..
View frank moran's Photo Album
Casino Cash: $7556
Mark, good information. Have you experienced any lifter failure as a result of belt failure and piston valve contact? I am chasing a noise and I'm hearing some valve lifter noise that may be the culprit??? Today I am putting a tech 2 to look at the KS's just to eliminate spark knock...thanks.
  #4 (permalink)
Old 02-12-07, 01:01 PM
Casino Cash: $250
I have yes.....the test above shows any failures up nicely.....
  #5 (permalink)
Old 02-13-07, 03:18 AM
Casino Cash: $250
Ok bit more of a detailed reply for you (was in a rush last night).
If there is any detectable knock then the ECU automaticaly retards the timing by 20deg+ and throws a fault code....so unlikely to be spark knock...
At high mileage and with poor servicing the lifters can get tappy (as they can on any engine)...using the above method to clean them out normaly fixes this (the colour of the oil that comes out can be quite shocking and you can feel the grit in it!).
Also check the exhaust manifolds for ticking, earlier power plants used a pretty naff composite gasket setup which deteriorates with time, the replacements are a multilayer metal affair which is MUCH better...
Its a case of use a listening stick or length of tube to pin point the noise.....
  #6 (permalink)
Old 02-13-07, 09:55 AM
Casino Cash: $7556
thanks mark, it's not spark knock, KS doing their job. I'm going to have to look under it real well and see if anything is loose, used the stethoscope method but I can only get the noise on light acceleration, possibly the engine torgque is causing an interferencce drives me nuts...
Tags: ,
head, replacement
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
