Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: The Verdict Is In: Blown Head Gasket; Now What?
Old 01-20-07, 02:52 PM
Cadillac(s): Cadillac
View caterashaker's Photo Album
Casino Cash: $260
OKay, guys & gals; here's the skinny: blown head gasket...confirmed. What do I do next? On my eariler thread, "Question For The A-Team," I was wondering what was causing the coolant & oil leak. Well, I'm wondering no more...it's DEFINITELY a blown head gasket. So, what next; engine swap repair it, crate engine ect. I'm in need of ALL of you to help me out here. My Catera is absolutely primo but this head gasket thing has me bummimg. The mechanics where I had the oil cooler repaired told me that the head gasket repair was out of their league because they've never done one before so they're not even going to try. What DID happen was this: I went by the Caddy dealership where I've buddied-up to several of the mechanics. Their expert Catera mechanic said that in all his years as a Caddy mechanic, he's only seen 1 legitamate blown head gasket on a 3.0 litre engine and that was on a CTS NOT a Catera. So, they go the cheap way first; they told me to try the Alum-Na-Seal repair. They told me that they've done this easy fix on North Stars, 3.0's ect. and it's worked 90% of the time. My mechanics poured this stuff in yesterday and so far so good. But I'm looking at the long term issue here. Anyone have experience with the head gasket reapir and/or a crate motor and where to get one? My Cat is a 1998 with 167,000+ miles on it and I'd really like to keep her so hit me with your best shot...THANKS!
  #2 (permalink)
Old 01-20-07, 07:31 PM
View Boris's Photo Album
Casino Cash: $925
Re: The Verdict Is In: Blown Head Gasket; Now What?
I would look for a top end gasket set. They can't be that much if you stay away from Cadillac, if your local parts store or fel-pro doesn't have one you might try searching in Europe.
Pull the heads off (it really not that difficult) and inspect them or have a head shop inspect them for cracks.
Inspect the head gasket for the source of the leak and check the corresponding area on the head.
If the head/s are cracked you could find parts on ebay or if the cost is too great get a motor.
First thing I would do is tear it down and confirm what the damage is.
http://www.federal-mogul.com/en/
  #3 (permalink)
Old 01-20-07, 10:40 PM
Cadillac(s): 1994 Eldorado 1998 Catera 2004 SRX
View 1998catera's Photo Album
Casino Cash: $705
i also have a 1998 and when i blew my gasket they ran some new stuff through that they got at a gm tech show...so far i have had no problems whatsoever...not even a sign of a leak...you should be good for quite awhile!
  #4 (permalink)
Old 01-20-07, 11:29 PM
View guardian's Photo Album
Casino Cash: $670
For me a no-brainer given the number of miles on your present engine. It owes you nothing and has served really well:
When (if) the Alum-Na-Seal gives up the ghost, just throw in a rebuilt engine and try for another 150,000+ miles. It's gonna cost you circa two grand but who cares. It is time and with the present engine you already are a winner. Trees do not grow to the sky. All things come to an end - eventually.
JMHO of course, as always.
  #5 (permalink)
Old 01-22-07, 04:01 AM
Cadillac(s): Vaux Omega (Caterra)
View Marks DTM Calib's Photo Album
Casino Cash: $250
SO....how does this sealent fix the oil leak then......
Did they detect hydrocarbons in the header tank.... (about THE only definative way of checking)
  #6 (permalink)
Old 01-22-07, 01:59 PM
MyOpel's Avatar
Cadillac(s): 2001 Catera Y57XE
View MyOpel's Photo Album
Casino Cash: $9417
When was the last time you replaced the heater control valve?
The way it is positioned, when it fails it will spray coolant into the valley of the engine and then the coolant will run down the back passenger’s side onto the exhaust manifold.
I recently had this happen to me. The steam came out from under the hood and for some reason had the sent of oil. I replaced the control valve and all is fine.
  #7 (permalink)
Old 01-24-07, 03:13 PM
Casino Cash: $260
Thanks guys for all your opinions. The oil is STILL leaking, for the most part, the liquid Alum-Na-Seal is holding, I changed the HCV over last summer and Mark, I don't know about the oil leak. I bought some Gummout Stop Oil Leak last night; too soon to tell if it's working. Guardian, you're absolutely right and I appreciate your thoughts. By the way, does anyone know where I can find a re-built engine?
  #8 (permalink)
Old 01-25-07, 12:37 AM
Casino Cash: $670
Originally Posted by caterashaker View Post
Thanks guys for all your opinions. . . . . . Guardian, you're absolutely right and I appreciate your thoughts. By the way, does anyone know where I can find a re-built engine?
Always happy to be of service.
I have not used this guy myself. But I believe others here have:
http://cgi.ebay.com/ebaymotors/CADIL...spagenameZWDVW
You are going to have the cost of shipping, of course, and installation unless you do the work yourself. Bottom line is going to come in at circa two grand, perhaps a bit more depending on details.
You have to admit, though, it's a sharp looking power plant.
  #9 (permalink)
Old 01-25-07, 11:31 AM
Casino Cash: $260
Guardian, that info is the bomb! THANK YOU VERY MUCH! 2 Grand for a new motor? Heck, I'll buy that, maybe not tomorrow but so. Thanks again to all of you guys.
  #10 (permalink)
Old 01-30-07, 02:33 PM
View Searayjba's Photo Album
Casino Cash: $440
If it helps, I had the same decision to make with a 1999 Cat, though not in as good shape as yours. Had already sunk $3K buying it when the head gasket blew. It had 103K miles on it, but the early Cat engines had a lot of problems (timing belt tensioner causing blown engines for one), so was not sure If rebuild was a good idea.
I contacted the guy with these engines on eBay. They bought a container full when the Cat went out of production. This is the 2003 engine so a lot of the problems were fixed on this engine, and he is well versed in these and very willing to discuss with you. He even talked with my mechanic when they had a small oil leak after the install. Cost was $1499 + $300 shipping (he air freights everything unless you are in LA area and can pick up.)
I've had the engine in for about 6 months without problems. Runs like a top. Now I just have the ETBCM and Air Bag light problems, but that's another story.
I would highly recommend this guy. Good luck.
  #11 (permalink)
Old 01-30-07, 03:53 PM
Cadillac(s): '97 Forest Green Catera
View investor74's Photo Album
Casino Cash: $5954
Is this the same as the CTS 3.2 engine? They didn't make Cateras in 2003.
Also, about how much did you pay for installation? What type of mechanic did you go to?
Thanks,
Barry
  #12 (permalink)
Old 01-30-07, 09:15 PM
Casino Cash: $260
Wow! Thanks Searayjba! Perhaps I should start saving up money now because I REALLY love my Cat but it's great to hear from someone who has actually bought 1 of those ebay engines. So, tell me a little more about your ETBCM & AIR BAG problem, specifically, what's up. Give me detail about when it happened & any other pertinant info & I'll ask my buddies at the Caddy dealership where I shop to help. Also, you might want to post a message on this forum address to Marks Calib DTS. He's brilliant and seem to have encountered virtually every problem with these quirky little cars that we all seem to have a love-hate relationship with.
Tags: , , , ,
blown, gasket, head, verdict
