Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Lean Bank
Old 01-16-07, 10:06 AM
miklman miklman is offline
View miklman's Photo Album
Casino Cash: $250
Lean Bank
Hello All!
Took 2000 Catera to shop for "check engine" light on. They said the left bank was running lean. Would not tell me why. Is this something I can address in my driveway?
I've also noticed that it runs really rough when the temp drops below 40. Spits and sputters untill it quits or I shut it off. And when I restart , it's ok.
Thanks for any info!
  #2 (permalink)
Old 01-16-07, 11:57 AM
Marks DTM Calib Marks DTM Calib is offline
Cadillac(s): Vaux Omega (Caterra)
View Marks DTM Calib's Photo Album
Casino Cash: $250
Re: Lean Bank
Would be best if we could get details of the stored fault codes.
Any recent work around the valley area of the engine..?
First thoughts are a faulty injector (rare), MAF I suspect is ok as this would affect both banks.....ignition fault would result in rich mixture as would an exhaust leak....again, realy need the fault codes...
  #3 (permalink)
Old 01-17-07, 02:12 PM
2001sport 2001sport is offline
View 2001sport's Photo Album
Casino Cash: $250
Re: Lean Bank
Actually, I believe there have been a number of people on this forum, including myself, that have solved lean bank 1 (code P0171) CELs by replacing the MAF. I've also read that the fuel filter could be a potential cause...
  #4 (permalink)
Old 01-18-07, 03:40 AM
Casino Cash: $250
Re: Lean Bank
As with any fault, you do not simply replace components without a formed diagnosis....
MAF is unlikely due to:
a) Lambda control will correct air measurement problems once the vehicle is warmed up and hence the ECU will report a general low/high MAF reading...
fault code
b) The MAF measures air to both banks....so why would only one report lean.
I am still yet to see an in service MAF failure in all my years of working on these....I have seen many MAF fault codes but never a real failure.
The trouble is the MAF is a very miss understood beast and most techs these days are simple creatures....if a MAF failure is suspected then further work needs to be done to confirm it i.e.:
1) Scantool operation of the EGR whilst monitoring MAF readings
2) Vac gauge tests to check for un-metered air getting in...
The question I asked above was slightly loaded as in relaity there is only one real thing that can cause a lean bank which the ECU can not correct and that is a lack of fuel.
The valley question was based on past experience where people in a rush have faield to spot the multiplug connector for the injector/inlet assembly and removed the connections from the injectors, these are difficult to get back on unless you know how and hence there might be an intermittent injector.
Again, this could also be a blocked fuel filter (surely these are changed are the correct service intervals ), this is normaly pretty obvious when revving as the car struggles at higher revs almost as if a limiter is kicking in....and would normaly affect both banks....
Hence, more info needed before diving in with willy nilly part replacement which only adds more confusion to the diag i.e.
'Was the replacement part faulty, or not, or was it not that part at all....'
Tags: ,
bank, lean
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
