My mistake, missed a dash out:
http://www.wheels-inmotion.co.uk/
The method that I use for basic camber setting involves the use of a flat piece of road/driveway and a modified spirit level.
In the spirit level is two drilled and tapped holes which have two long(ish) bolts inserted with a locking nut also, the holes are spaced so that the heads of the bolts rest on wheel rim.
You can then set the bolt lengths by winding them into the threads (and locking them in place with the nuts) so that when the spirit level is vertical any object placed on the heads of the nuts will be a set angle relative to the vertical....
In this case the object we are using is the wheel rim.
Considering the target camber setting is 1deg and 20sec (i.e. 1.33333deg) and using a bit of trig (Tan) you can work out thedifferent required between thetwo bolt lengths and adjust the boltss.
Now with the car on a flat surface (at least left to right) you can jack the car up remove the road wheel, slacken the the hub to strutt joint bolts, refit the wheel and set a basic camber setting (by pushing/pulling the top of the wheel) using the spirit level with the bolts resting on the wheel rim, given that your bolts are correctly set, a vertical reading is the correct camber.
Remove the wheel again and nip the bolts back up, refit wheel and roll the car backwards 6 feet and then forwards again and re-check with your spirt level...
Repeat until accurate and torque the bolts up fully.
Now do the other side.
What you should find is that the top bolt on the level will stick out about 7-10mm more than the bottom one (differs with wheel rim diameter).
Given what you are doing it should be fine to only fit three wheel bolts whilst doing the adjustments.
You might find thatchecking the camber with the fabricated gauge and moving the strutt with the wheel off and then simply clamping it again works best for you.....its down to personal preferrence...
