Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: 2000 Catera with many problems!
Old 01-15-07, 09:57 AM
caddydaddy's Avatar
caddydaddy caddydaddy is offline
Cadillac(s): 93 Coupe DeVille, 94 Deville, 2000 STS
View caddydaddy's Photo Album
Casino Cash: $1367
Question 2000 Catera with many problems!
I'm trying to help a friend that has a 2000 Catera with a few problems. The car has had many electrical modules problems .
First set of problems that have already been fixed
Stereo System not working (no power to system)
Gas Door will only open when car in drive, not park
Trunk will only open when in drive not park
(Resolution was new module)
2nd set of problems not fixed
All of these dummy lights are on
1.Anti Lock Brakes (and when this goes on speedometer stops working)
2.Air Bag Warning light is on
3.Traction Control Warning light is on
4.Check engine Light is on
5. Seems at times head lights not working properly, shorting out on drivers side
Transmission seems at times to run rough.
Is it fairly easy to check for computer codes on the Cateras? I've never worked on one of these cars.
Thanks!
  #2 (permalink)
Old 01-15-07, 11:43 AM
Marks DTM Calib Marks DTM Calib is offline
Cadillac(s): Vaux Omega (Caterra)
View Marks DTM Calib's Photo Album
Casino Cash: $250
Re: 2000 Catera with many problems!
First off....measure the battery volateg with the engine revving at 3000rpm....
Many ECU lights often points to an over volting alternator.....so rule out the obvious first....
  #3 (permalink)
Old 01-15-07, 01:42 PM
caddydaddy's Avatar
Casino Cash: $1367
Thanks! I'll have them check that out. What should the voltage be, around 13-15 volts?
  #4 (permalink)
Old 01-16-07, 03:45 AM
Casino Cash: $250
It should peek at about 14.4V (these use a Calcium battery which requires a slightly higher charge voltage), any more and the ECU's will go into limp mode and report a high voltage code....
  #5 (permalink)
Old 01-16-07, 02:32 PM
Searayjba Searayjba is offline
Cadillac(s): Cadillac
View Searayjba's Photo Album
Casino Cash: $285
Re: items 1,3,&4 - Probably a bad ETBCM, or connector. The speed signal comes from the Vehicle Speed Sensor located on the transmission, and feeds thru the ETBCM to the speedo, traction control system and ABS. The ETBCM has been a problem on the Cat, at least according to multiple forums. If it is bad the speed signal doesn't make it to the other systems so you get the error lights. Also, your cruise control probably doesn't work; no speed signal.
The ETBCM can be rebuilt, check eBay for 2 companies who do this for about $200. Much cheaper than new (about $750, also eBay).
Hope this helps.
  #6 (permalink)
Old 01-17-07, 03:52 AM
Casino Cash: $250
This is NOT the case.....the speed signal is derived from the rear ABS sensors.....the transmission speed sensor is used by the transmission only!
Tags: , , ,
2000, catera, problems
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
