  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: VSS 'a' malfunct. and EBTCM
Old 12-30-06, 08:43 AM
Cadillac(s): Cadillac
View BlckCat's Photo Album
Casino Cash: $250
Hi Guy's
First, a happy and healthy new year to one and all.
My ongoing EBTCM issue is starting to feel more than a little annoying!!
As BORIS suggested, I retraced back the remote starter fitment, the brain for that was removed and it made no difference at all, so that has helped narrow it down a bit, thanks Boris.
The reconditioned EBTCM has stopped throwing up codes (CEL ones) and the code coming up now is as follow's;
0500 - VEHICLE SPEED SENSOR A MALFUNCTION
My question, where is 'A' and anyone have an idea of cost etc, or whether it is likely that it could be the culprit behind the problems I now have.
I will go grab one and fit it, if it makes sense.
Thanks All.
Mick
  #2 (permalink)
Old 12-30-06, 11:27 AM
Banned
View contourbs's Photo Album
Casino Cash: $250
Re: VSS 'a' malfunct. and EBTCM
im not for sure but i was told it gets it signal from the right rear speed sensor, so go check the passenger rear speed sensor and see if it looks ok
  #3 (permalink)
Old 12-30-06, 02:44 PM
Casino Cash: $250
Thanks Contour!!
Ironically the vehicle had the back brakes done just prior to the onset of this problem, I wonder!! Not to ask a totally ignorant question, but what should I actually look for in terms of the rear sensor?
Having had the EBTCM done, I am loathe to purchase a VSS before I know if its actually required!!
Coincidentally, and it may be just that, I have developed a strange braking problem, if I apply much pressure, the car shifts sideways and back and the steering wheel kicks. My understanding being that if I don't have the ABS running, it would brake as normal, just that the anti-lock would not function, makes me wonder if the ABS has partial activity.
Snow (a little bit) arrived today, and the combination of rear wheel drive, no tracs or abs is making life a little exciting!!
Anybody else seen any of the above?
  #4 (permalink)
Old 12-30-06, 07:26 PM
Banned
Casino Cash: $250
take the right rear tire off and check the sensor and look for anything the unusual
  #5 (permalink)
Old 01-05-07, 05:58 PM
View Searayjba's Photo Album
Casino Cash: $440
I too have the EBTCM problem. It first showed up after I had the engine replaced. The mechanic sid ti was probably the VSS.
I bought one off eBay, not too expensive. Is fairly simple to install.
The VSS is located on the transmission, a little high on the drivers side. It's held on with a single bolt. Carefully remove the connector, remove the bolt and carefully pry it out. It has an "O" ring seal so may need to work it a bit.
I had to jack up the drivers side of the car to get under, but it was fairly straight forward.
BTW it didn't help with my EBTCM problem and I am now looking into one of the 2 rebuild offers on eBay.
Good luck.
  #6 (permalink)
Old 01-05-07, 06:37 PM
Banned
Casino Cash: $250
if im correct the speedo doesnt get it signal from the sensor on the trans, it gets it from the r/r speed sensor and then goes to to ebtcm module so yeah get it rebuilt from bba off ebay
Tags: , ,
ebtcm, malfunct, vss
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
