Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: throttle body cleaning
Old 12-17-06, 08:31 PM
todd2fst4u's Avatar
todd2fst4u todd2fst4u is offline
Cadillac(s): 1998 Catera
View todd2fst4u's Photo Album
Casino Cash: $6159
i bought some throttle body cleaner today. before i start i have a few questions. after i clean and start up the car, is the check engine light going to come on? if yes, can i clear the check engine light by simply disconnecting the battery?
  #2 (permalink)
Old 12-18-06, 11:14 AM
PEETYZ's Avatar
PEETYZ PEETYZ is offline
Cadillac Owners Enthusiast
View PEETYZ's Photo Album
Casino Cash: $1902
Re: throttle body cleaning
It should not come one if so i would say you could clear it that way or go to Autozone. Your best bet for it not to go off is to park your car down hill front end down that way all the black stuff that comes off when u spray the cleaner will run out the front of the egine and not back into it get a few old rags and a toothbrush and open and close the intake with your hand by pressing down the lever on the top left side of motor The easiest way is to loosen both top and bottom clamps so you can really get in there with nothing in the way Best of Luck -Pete
  #3 (permalink)
Old 12-19-06, 11:19 AM
Marks DTM Calib Marks DTM Calib is offline
Cadillac(s): Vaux Omega (Caterra)
View Marks DTM Calib's Photo Album
Casino Cash: $250
Assuming this is the X30XE unit (3.0 24V) then I would remove the plenum (simply 4 bolts, throttle cable, cruise cable, EGR pipe, Brake servo pipe etc) and clean the breather system fully at the same time
Next check the main engine breathers that attach to the rear of the plenum assembly (two large that join and one small, the large and small connect to a breather box at the rear of the 1-3-5 cylinder bank). Clean as required.
Remove the throttle body, its only 4 bolts and makes cleaning one hell of a lot easier!. Note, paint stripper works very well on carbon deposits if the cleaner isnt doing the job.
Now unlcip the plastic cover from the breather bridge on top of the plenum, this will reveal a bolt which allows removal of the breather bridge.
Clean this well in carb or similar cleaner.
Also, pop the idel valve from theside of the plenum and clean this well with carb cleaner.....repeat a few times to make sure its fully cleaned.
This way you know the engine is breathing well, the crank case wont get pressurised and your cam cover gaskets wont blow plus your idle vale and throttle body is now nicely clean which improves driveability and idling.
Sorry for diving in, I run a Vauxhall/Opel Omega (europeon Caterra) site in the UK...........
www.omegaowners.com
Tags: , ,
body, cleaning, throttle
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
