Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Antifreeze leak?
Old 12-17-06, 03:50 PM
2000ForrestGrnCatty's Avatar
2000ForrestGrnCatty 2000ForrestGrnCatty is offline
Cadillac(s): 1992 STS
View 2000ForrestGrnCatty's Photo Album
Casino Cash: $1636
Antifreeze leak?
I just put some antifreeze in the plastic tank under the hood, then about 5
days later, the low fluid light for the antifreeze came on the dash.It was almost empty. I poured in some more and about a week later the same thing occured. Is this the sign of a possible leak?
  #2 (permalink)
Old 12-17-06, 07:00 PM
contourbs contourbs is offline
Banned
Cadillac(s): Cadillac
View contourbs's Photo Album
Casino Cash: $250
Re: Antifreeze leak?
i would say YES, pressure test and see where its leaking its a no brainer that its leaking
  #3 (permalink)
Old 12-17-06, 09:53 PM
Casino Cash: $1636
Thanks for your astute observation. Smartass.
  #4 (permalink)
Old 12-17-06, 10:36 PM
Banned
Casino Cash: $250
well you car keeps losing coolant, what do you think is happening
  #5 (permalink)
Old 12-18-06, 08:02 AM
guardian guardian is offline
View guardian's Photo Album
Casino Cash: $400
Hey cool it with the name calling. That doesn't fly in this group.
It does seem as if you could have a leak. I assume you are not seeing coolant on the floor, or you would have told us. This leaves two possibilities - neither one is good sorry to tell you:
You need to look for any signs of coolant in your oil. Hope you do not find any, but it has happened with other Cats. You might have a leaky heat exchanger, aka "oil cooler".
The other possibility, and I hate even having to mention it, is that coolant is being blown out your tail pipe. This could come as a result of possible problems - a leak - with one of your head gaskets.
Either way above, or even if it is something else, you are correct to be concerned about something like coolant loss. At this point you need the help of a competent diagnostician.
Wishing you good luck. I hope you can find the problem, get it fixed, and still have something left in the piggy bank for Christmas!
  #6 (permalink)
Old 12-19-06, 11:52 AM
Marks DTM Calib Marks DTM Calib is offline
Cadillac(s): Vaux Omega (Caterra)
View Marks DTM Calib's Photo Album
Casino Cash: $250
Assuming this is the Catera with the X30XE engine then the most common coolant leak problems, in the following order, are:
1) Heater bypass valve - rear of engine near bulk head (fire wall)
2) Thermostat to lock seal
3) Oil cooler plate to block seal
Remember, if you have an oil cooler failure you get more coolant (although its a thick mayo) as the oil gets into the coolant system.........not less.
  #7 (permalink)
Old 12-19-06, 04:54 PM
Casino Cash: $1636
Look Man, this guy didn't have to get flippant with me because I asked a question. What
goes around comes around.
  #8 (permalink)
Old 12-19-06, 05:35 PM
lakesidepark lakesidepark is offline
Cadillac(s): 1997 Catera
View lakesidepark's Photo Album
Casino Cash: $1697
Talking Re: Antifreeze leak?
I am a frequent visitor to this and other technical forums. I did not see contorbs' remarks as flippant. He was merely pointing out that the symptom was obvious (coolant is there then it's low, so therefore must be losing coolant).
Therefore "it's a no-brainer". That is not flippant. It is kinda a technician attitude.
The proper response would have been "duh, stupid me...yeah I guess I am losing coolant...got any ideas why??" instead of the aggressive grammatic approach. This would have pointed to us that you were competant enough to understand the next suggestion and were simply too distracted to notice you said "I have symptoms of a leak...is it possibly a leak?". You would have noted to the audience that you understand technical concepts and therefore would not be wasting their time trying to help you. And you would have shown the readers here that you could take some fun having such obvious things pointed out.
But you showed a bit of arrogance and some denial of your own fallibles. You did not thank him for answering your question (you asked if it was a possible leak, he said YES), and you showed no appreciation that he even suggested a course of action (pressure-test and see where).
It could be difficult to expect good assistance unless you are able to loosen up a bit and go with the flow. It could be said that contorbs is a "smartass", but in my experience as a technician that skill is required to be able to smile when someone hands you a broken part and asks if the two individual pieces means it is a broken part.
intelligence does NOT negate stupidity
  #9 (permalink)
Old 12-20-06, 12:26 AM
tmkktm tmkktm is offline
View tmkktm's Photo Album
Casino Cash: $250
Absolutely inadmissible! Contourbs has always been helpful and as well as the rest of the group. If you don't like the advice, don't take it and go away.People are here to help each other!!! Even your second comment was unecessary.Don't get mad at people because your car is broken. So, do you have water in the oil or any in the exhaust?
  #10 (permalink)
Old 12-20-06, 12:29 AM
Banned
Casino Cash: $250
its hard enough to try and fix these cars in person and makes it 10 times harder over the internet. so when you ask a question know what your talking about
Tags: ,
antifreeze, leak
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
