I don't know what bolt pattern these rims have. If they have 5x115 CB 72mm then you can use adaption wheel spacers (picture below). These spacers are bolted on the hub (with 5x110) and the wheel is bolted on the spacer (with 5x115). But the spacer is 25mm thick and therefore it reduces the offset of the wheel. If you adapt a wheel with an offset of 35mm you will end with an offset of only 10mm. This could be a bit too closely to the wheel housing.
In Germany you can get such adapters here:
http://www.spurverbreiterung.de/index.php?c=true&lan=uk but i think there should be also someone in the US, who farbicates these.
