| Re: What Is the Final Word on Ebay Headlights? The set I got was from the UK and it had a lever that would move the left hand bump of light down and make it a flat beam...
WHat you need to do is pop off the high beam cover and stick your fingers in there and you will feel it, then simply move it up...
NOw for US, you may have to take those apart and then remove the projector, disassemble the front lens, flip around the cutoff shield or make new ones by using the old ones as a template... then reinstall everything and you should be good to go... |
