Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Preventative Maintenance ADD YOUR TIPS!
  #21 (permalink)
Old 11-25-06, 09:48 AM
andergar's Avatar
andergar andergar is offline
Cadillac(s): '00 Catera
View andergar's Photo Album
Casino Cash: $540
Re: Preventative Maintenance ADD YOUR TIPS!
Caterashaker, when you did the throttle body cleaning did you get any error codes? I want to clean my today,but I'm afraid of getting a code.
Thanks
Steve
andergar@comcast.net
  #22 (permalink)
Old 11-26-06, 04:50 PM
PEETYZ's Avatar
PEETYZ PEETYZ is offline
Cadillac Owners Enthusiast
View PEETYZ's Photo Album
Casino Cash: $1902
do you disconnect the two tubes that go into the engine via Air intake and spray and clean from there?
  #23 (permalink)
Old 11-27-06, 12:01 PM
andergar's Avatar
Casino Cash: $540
I did and held open the butterflies open with a screw driver. A lot of black stuff ran out of the throttle body. Now the bad news. I had seven engine error codes go off. I had to go to Autozone to clear the codes. Everything good after that. The codes were a misfire in each cylinder and a MAF error. I talk to my local mechanic and he recommends a professional throttle body and fuel injector cleaning at this shop. Cost is about $180 and two hours of time. I'm going to do this in the few days. He recommends this every 30 - 45k miles. I'll report in next week on the results.
Steve
  #24 (permalink)
Old 12-01-06, 01:35 AM
caterashaker caterashaker is offline
Cadillac(s): Cadillac
View caterashaker's Photo Album
Casino Cash: $260
Sorry for the delay guys. Andergar, no, I didn't get any codes. I think the mechanic is right but I think that that's $180 bucks too much for something that you can do yourself. The misfires were from all the gunk and run-off from the cleaner finding it's way into the combustion chamber. You did the right thing by taking it to Autozone and having them clear the codes for you. By the way, what brand of throttle body cleaner did you use? Pete, yes, disconnect the 2 black plastic hoses that go from the air box to the plenum and go to town with the spray. Hold the throttle blades open and do both sides. Refer to my first post. Cleaning the throttle body is easy and effective. Keep me posted.
  #25 (permalink)
Old 12-05-06, 03:32 PM
andergar's Avatar
Casino Cash: $540
Sorry for not getting sooner caterashaker. The throttle body cleaner I used was GM brand. My mechanic ended up only charging me $140. This is my first full tank of gas to see if my mileage is any better. I'll let you know. Soon.
Andergar
Steve
  #26 (permalink)
Old 12-05-06, 06:50 PM
PEETYZ's Avatar
Casino Cash: $1902
wow expensive i got a bottle of cleaner and did it myself for around 3 bucks i parked down a hill so all the bad gum and other black stuff ran out the front end & not into the motor i notice the difference already and mine were not to bad to begin with =)
  #27 (permalink)
Old 08-24-07, 07:31 PM
zealious zealious is offline
View zealious's Photo Album
Casino Cash: $270
When Oil Cooler fails, dont buy a 300 dollar replacement cooler, just re-route the lines to a air trans/oil cooler ($50) mount to the front of ur radiator near the fan, never worry about cooler again.
You can grab some sloted and cross drilled rotors for about 90 a pair off ebay. (cheaper and better than stock)
what ive done with my air box is left the stock one because hot air is pointless.. I upgraded to a K&N in stock box but I improved the piping from the front of the car. I took off the front piece that is mounted to the grill and used larger custom piping. If you dont feel like going that route I belive just drilling holes in the box with the K&N would be bettter.
You can bypass your Heater blow off valve using a aluminum pipe.
thats all i got.
  #28 (permalink)
Old 08-24-07, 07:34 PM
Casino Cash: $270
also When I had my intake manifold off, I cleaned the throttle body.. also the entire intake housing, its good to get the ports as well. I even sprayed carb cleaner on the fuel injectors.
When you do this you might as well change your fuel filter. Its easy just remove ur rear passenger side wheel.
  #29 (permalink)
Old 08-24-07, 10:34 PM
rinverso rinverso is offline
Cadillac(s): 2001 catera
View rinverso's Photo Album
Casino Cash: $649
Thumbs up Re: Preventative Maintenance ADD YOUR TIPS!
Great job guys, i learned alot. it was so nice to get constructive, positive help instead of the usual idiots bashing the cat and saying how it sucks!! still loving my cat, hope to keep it long as posible. these maintiance items will certainly help.
thanks again for the positive input!!
robert
  #30 (permalink)
Old 08-25-07, 12:54 AM
elvin315's Avatar
elvin315 elvin315 is offline
Cadillac(s): Platinum 2001 Cadillac Catera Sport
View elvin315's Photo Album
Casino Cash: $8516
Originally Posted by andergar View Post
My question is if the air filter is open in the engine bay, where is it getting the cold air? The engine bay produces a lot of heat.
My thoughts exactly. I've only found pictures of 2 true cold air induction systems on a Catera/Omega. Both have shortcomings.
Hood Scoop 1
Hood Scoop 2
Under Bumper 1
Under Bumper 2
Elvin
Tags: , , ,
add, maintenance, preventative, tips
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
