| Re: Leveling Light Flashing I had that same problem, the compressor will run untill the leveling sensor located at the rearend, sees that the car is leveled out and shuts off the compressor. I had a leak in the air lift component of the right rear shock, so the car never got back to level. BUT there is a timer that should trip the compressor after 2.5 minutes if there's an air leak or the compressor is defective. Also if relay K19 is not energizing or the contacts to the compressor are not closing, you'll get the leveling warning light.
So check the compressor by putting 300 lbs ( a couple of your friends or maybe not so much friends,) in the trunk. start the car. after about 25 seconds check the compressor ,located ahead of the right front wheel, and see if it runs. If you need more help, I'll type some more.
good luck.
Jerry O
