| Re: 98 Catera keeps cutting off once it gets warm Need Help Did the engine temperature gauge read high? Did you get a "Check engine" light?
Have you had the DTC codes read?
Anyway the fans operate independantly of the ECM.
The primary cooling fan temp switch is located on the LH upper side of the rad.
The secondary cooling fan temp switch is located on the LH lower side of the rad. They operate through fuses, 40, 42, 50 and 52. Check them if your fans aren't working. Also relays K26, 28, 48, 52, 67 & 87 for the fans are located in the engine compartment ECM housing. See your owners manual , section 6 for locations.
In closing, I haven't found a temperature switch that will cut out the engine for any reason.
Good luck. |
