| Re: Check Engine Error Code PO411 Had the same problem about a year ago on my 2000 sport. Read some were that you climb under the car and pull the hoses off the air pump and blow through them and then suck on them to see if they are blocked. I did that and found out that one was clogged, blow it out with my air compressor and have had no problem with it since. I also read that bad gas or gas with to low of octane will all so cause the light to come on with that code. My sport had 50k on it when it happened. Hope i could help |
