Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Transmission: Range Switch
Old 07-13-06, 11:46 AM
CtA318 CtA318 is offline
View CtA318's Photo Album
Casino Cash: $250
What is the range switch on a transmission?
Where can I get one?
Are they easy to replace?
I cant find any information in the GM service manuals. Maybe it is under a different name.
  #2 (permalink)
Old 07-16-06, 08:43 PM
1986cimarron's Avatar
1986cimarron 1986cimarron is offline
View 1986cimarron's Photo Album
Casino Cash: $250
Re: Transmission: Range Switch
Need to confirm the year but here is one for a 98 model.
Document ID# 257107
1998 Cadillac Catera
DTC P0705 Trans Range Switch Circuit
Circuit Description
The Transmission Range Switch is attached externally to the left side of the 4L30-E transmission on the gear selector shaft. The Transmission Range Switch informs the TCM and the Gear Position Indicator (on the console) which gear the driver selects.
The ignition voltage applies to terminal D of the Transmission Range Switch. Depending on the selector lever position, this ignition voltage connects to the various combinations of terminals A, B, C, and G of the Transmission Range Switch. The TCM decodes these combinations in order to determine gear position.
Conditions for Running the DTC
The ignition is on.
Conditions for Setting the DTC
The switch indicates an undefined position for longer than 20 seconds.
Action Taken When the DTC Sets
The TCM illuminates the Service Transmission Lamp (STL) and sends a MIL Request to the ECM on the second consecutive drive trip that the diagnostic runs and fails. The ECM then illuminates the MIL.
The ECM records the operating conditions in the Freeze Frame at the time of the MIL Request from the TCM.
The transmission operates in the Default Mode.
Conditions for Clearing the MIL/DTC
The TCM turns off the STL as soon as the fault is no longer present.
The ECM turns off the MIL after three consecutive drive trips during which the TCM sends no MIL Request.
A History DTC clears after forty consecutive warm-up cycles, if no failures are present by this diagnostic or any other emission related diagnostic.
The scan tool clears the MIL/DTC.
Diagnostic Aids
Use the Connector Test Adapter Kit J 35616-A for any test that requires probing the TCM harness connector or a component harness connector. Using this kit will prevent damage to the harness connector terminals.
Check for the following conditions:
Poor connections at the TCM or at the component. Inspect the harness connectors for any backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and poor terminal to wire connection. Refer to Engine Electrical, Troubleshooting Procedures, Checking Terminal Contact for proper procedure.
Damaged harness. Inspect the wiring harness for damage. If the harness appears to be OK, observe the scan tool while moving any related connectors and any wiring harnesses. A change in the display may help to locate the fault.
Test Description
The number(s) below refer to the step number(s) on the Diagnostic Table.
The scan tool display should match the selector lever position at each detent stop. If the lever has to be moved slightly within a position to get the right indication on the scan tool, the Transmission Range Switch adjustment should be checked. Refer to Automatic Transmission, On-Vehicle Service, Transmission Range Switch.
Terminal D in the mating connector (harness side) can be used as the power source.
DTC P0705 - Transmission Range Switch Circuit Step
Action
Value(s)
Yes
No
1
Was the Powertrain On-Board Diagnostic (OBD) System Check performed?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
Turn off the engine.
Turn on the ignition.
Shift through all of the selector lever positions while observing the Transmission Range on the scan tool.
Does the scan tool display agree with the selector lever in all of the positions?
P, R, N, D, 3, 2, 1
No trouble found
Refer to Diagnostic Aids
Go to Step 3
3
Disconnect the Transmission Range Switch.
Use the test light J 35616-200 connected to ground in order to probe terminal D in the harness connector (harness side).
Does the test light illuminate?
Go to Step 4
Go to Step 6
4
Use a fused jumper in order to jumper terminal D in the harness connector (switch side) to B+.
Use the test light J 35616-200 connected to ground in order to probe all of the terminals in the harness connector (switch side) in each selector lever position. In the following list, only the specified terminals should illuminate the test light in a given gear position:
- P: Terminals D, A, G
- R: Terminals D, A, B, F
- N: Terminals D, B, G
- D: Terminals D, B, C
- 3: Terminals D, A, B, C, G
- 2: Terminals D, A, C
- 1: Terminals D, C, G
Did the test light illuminate on the proper terminals in each gear position?
Go to Step 5
Go to Step 9
5
Reconnect the Transmission Range Switch.
Turn off the ignition.
Disconnect the TCM.
Turn on the ignition with the engine off.
Probe terminals 8, 23, 26, and 33 in the TCM harness connector in each selector lever position with the test light J 35616-200 connected to ground. In the following list, only the specified terminals should illuminate the test light in a given gear position:
- P: Terminals 23, 33
- R: Terminals 23, 26
- N: Terminals 26, 33
- D: Terminals 8, 26
- 3: Terminals 8, 23, 26, 33
- 2: Terminals 8, 23
- 1: Terminals 8, 33
Go to Step 11
Go to Step 7
6
Repair the ignition feed circuit to the Transmission Range Switch.
Is the action complete?
Go to Step 13
7
Check the Transmission Range Switch harness connector for a poor connection or poor terminal tension. Refer to Engine Electrical, Troubleshooting Procedures, Checking Terminal Contact for proper procedure.
Was a problem found and corrected?
Go to Step 13
Go to Step 8
8
Check the affected circuit(s) for the following conditions and repair as necessary:
• open/high resistance
• short to ground
• short to B+
Go to Step 13
9
Check the Transmission Range Switch for proper adjustment. Refer to Automatic Transmission, On-Vehicle Service, Transmission Range Switch .
Go to Step 13
Go to Step 10
10
Replace the Transmission Range Switch.
Go to Step 13
11
Check the TCM harness connector for a poor connection or a poor terminal tension. Refer to Engine Electrical, Troubleshooting Procedures, Checking Terminal Contact for proper procedure.
Go to Step 13
Go to Step 12
12
Replace the TCM. Refer to Automatic Transmission, On-Vehicle Service, TCM .
Go to Step 13
13
Clear the DTCs on the scan tool.
Turn off the ignition for 15 seconds.
Start the engine.
Operate the vehicle within the conditions required for this diagnostic to run. Refer to Conditions for Running the DTC.
Check for any DTCs.
Is DTC P0705 set?
Go to Step 2
Go to Step 14
14
Were there any additional DTCs noted during the Powertrain or Transmission OBD System Check that were not diagnosed?
Go to the applicable DTC table
Go to Step 15
15
Does the Transmission now function properly?
System OK
Go to Functional Test Procedure
Document ID# 257107
  #3 (permalink)
Old 08-17-06, 04:11 PM
normalicy normalicy is offline
Cadillac(s): Catera
View normalicy's Photo Album
Casino Cash: $285
Yup, that's it. It's more commonly refered to as the "Neutral Position Switch" or PRNDL sensor. It wasn't the electrical connection on mine. It was mechanical. There is a plastic part that attaches to the shaft & it broke in two. It kills me, because I pulled it apart & I'm sure it doesn't take more than $5 to make one of these things, however it's kinda expensive at the dealership ($300 range), but I was able to special order one through Autozone's website for $109. No one carried it in stock locally for me (Advanced Auto Parts, Autozone, Car Quest, O' Reilly's, NAPA). It worked perfectly for me. Do note that if you remove it, that the center nut connecting the linkage is easy to snap & you will be stuck if that happens. So, pile on the WD-40 or whatever thread loosener you choose for a few days before.
  #4 (permalink)
Old 04-12-08, 12:46 AM
Cadi Cat Cadi Cat is offline
Cadillac(s): 2000 Catera
View Cadi Cat's Photo Album
Casino Cash: $3667
Went to the autozone website to see if I could order this part. (PRNDL) Is it also called the neutral saftey switch? It's roughly the same price as the previous post which is why I'm asking.
  #5 (permalink)
Old 04-12-08, 04:10 AM
Cadillac(s): Catera
Casino Cash: $285
What are you asking? If you want to make sure of the part#, it's JA4264.
  #6 (permalink)
Old 04-12-08, 01:26 PM
Casino Cash: $3667
that's it, thank you very much!
Tags: , ,
range, switch, transmission
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
