Originally Posted by gritter Right now i have 225/55/r16's on the stock catera rims but my tires are pretty worn. My dad has a pair of his 225/60/r16's in his garage with like 90% tread left. Will these tires fit? Or will i see rubbing in some area? |
Gritter please be really careful. You could be injured.
The 60 aspect ratio tires might "fit" onto your Catera rims. But they might not fit properly in the sense that the bead of the 60's might not perfectly match the rim. This could leave you with an impaired seal which would reveal itself, for example, during hard cornering or at high speeds.
You need to know if your rims are certified to run tires with a 60 aspect ratio, and I do not have that answer. If another owner here has been running 60's on stock Catera rims I hope that owner will report his experience for your benefit.
But if your rims are not certified for the 60's, you should not run them even if they fit. To do so would be really unsafe and would place you and your car at risk.
Good luck and please be careful.
