  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Can't find in shop manual/valve gasket replament
Old 03-13-06, 11:53 PM
View rapster37's Photo Album
Casino Cash: $300
Can't find in shop manual/valve gasket replacement
I just bought the 3set 2nd edition 1998 Catera shop manual. I can't seem to find the page in replacing the gasket. The only thing I see is something on the camshaft and intake manifold. Are the same as the valve cover?
  #2 (permalink)
Old 03-15-06, 08:20 AM
Omega_man's Avatar
View Omega_man's Photo Album
Casino Cash: $250
Re: Can't find in shop manual/valve gasket replament
Hello,
Are you trying to find out how to replace the gaskets under the black cam covers?
James.
  #3 (permalink)
Old 03-16-06, 12:53 AM
Casino Cash: $300
Yes James.
  #4 (permalink)
Old 03-16-06, 02:53 AM
Omega_man's Avatar
Casino Cash: $250
Hello,
http://www.vauxhallownersnetwork.co....ad.php?t=63628
This links to a How To on the UK Omega forum, for this exact job. A couple of points to add from my experience of doing the job.
1 - Access is improved if you remove the wipers and scuttle first (a 5 min job)
2 - Long nose pliers are ideal for removing the bolts from the inlet bridge (bit below the plenum chamber)
3 - Remove the black crankcase vent pipes and blast them through to clear any crud out
4 - Use only the black sealant, Cadillac should be able to supply that.
5 - Saturate the EGR valve bolts overnight in WD40 or whatever penertrating oil you have in the states .
6 - Take your time, worst case, invisage having the car off the road for 2 days.
7 - All the advise given in the above link, and info above is to be used entirely at the owners risk, no responsibility for potential damage to person or car is accepted .
8 - If unsure, label where all wire connectors plug into, with those luminous permanent coloured markers.
Hope this helps.
James.
  #5 (permalink)
Old 03-17-06, 01:03 AM
Casino Cash: $300
James,
Wow!! Thank you soooo much. The book does not detail it the way you did. I can go ahead now get the work done. I think a lot of user here in the forum will love what you have done.
Hey James, If you have anymore work you've done on your car please send to me...either here in the forum or send to me here redmaster1@msn.com.
  #6 (permalink)
Old 05-28-06, 10:52 PM
1986cimarron's Avatar
View 1986cimarron's Photo Album
Casino Cash: $250
Document ID# 247808
1998 Cadillac Catera
Camshaft Cover Removal
Remove the oil filter tube from the driver side valve cover.
Remove the valve cover bolts (2).
Remove the valve cover (4).
Important
Ensure that all eight sealing O-rings (3) are accounted for. O-rings may stick to the camshaft bearing caps. O-rings may fall into the oil return journals in the cylinder head.
Remove the valve cover seals.
Document ID# 247808
Document ID# 248334
Camshaft Cover Installation
Lightly coat new seals, including the O-rings, with engine oil prior to installation to assist in holding the O-ring seals to the valve cover.
Install the valve cover seals.
Apply a thin coat of silicone sealer GM P/N 12345997 at the front and at the back of the seals.
Install the valve cover to the cylinder head.
Install the valve cover bolts.
Tighten
Tighten the valve cover bolts to 8 N·m (71 lb in).
Document ID# 248334
Tags: , , ,
find, gasket, manual or valve, replament, shop
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
