Headgasket?
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, Headgasket? in Past Cadillac Vehicle Discussion; 1997 Catera 94,000 Miles Recall work has been done. New starter, spark plugs, oil cooler, coolant cross-over bridge, and camshaft ...
    CtA318 is offline Cadillac Owners Member
    Dec 2005
    59
    AngryHeadgasket?
    1997 Catera
    94,000 Miles
    New starter, spark plugs, oil cooler, coolant cross-over bridge, and camshaft (valve cover) gaskets.
    I'm experience coolant loss at a rapid rate when my car is warmed up and driven. Being a lead foot burns it quicker. After the car has been driven for awhile smoke will arise from the left side (driver's side) of the engine compartment and you can smell coolant. Could this be headgaskets?
    The other obvious coolant leaks from that area were fixed aside from the heater control valve. Someone also mentioned that it may be a water pump but I didnt think it was that because I haven't noticed a puddle of coolant under the car.
    Another problem:
    Check engine light is on and it flashes. The car idles really rough. The engine shakes and I dont have much power behind the gas peddle. When the plugs were done the wires were not. I am assuming that the wires are bad and I'm getting a misfire. Bosch +4 plugs were put in there.
    R-Caddy's Avatar
    R-Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2 1997 Cateras: black&ocean green
    Jul 2005
    Savannah, GA
    32
    698
    Re: Headgasket?
    check for the mass ai flow sensor for rough idle. or air filter.
    Dec 2005
    59
    Re: Headgasket?
    I looked up the misfire on the computer and Im getting Random Misfire and a Misfire in #2 and #5,
