EBTCM Removal.... any tips. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Cadillac Catera and Cimarron Forum Discussion, EBTCM Removal.... any tips. in Past Cadillac Vehicle Discussion; Does anyone know if the ECBTM can be pulled from a wrecked vehicle and installed in another vehicle? Is there ...
  1. #16
    Charles Anderson is offline Cadillac Owners Member
    Nov 2004
    3
    Re: EBTCM Removal.... any tips.
    Does anyone know if the ECBTM can be pulled from a wrecked vehicle and installed in another vehicle? Is there any reason this shouldn't be done?
  2. #17
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Depends on the year and model.
    Some are plug and play, some require programming.
    Usually you can do it but you have to match up the numbers to be sure you have the right one, and if it needs programming it can be done, you just have to find someone that will do it.
  3. #18
    imprezave is offline Cadillac Owners Member
    Automobile(s): catera
    Oct 2010
    28
    27
    Hi guys,
    I'm doing this right now and I'm wondering if it would be easier to remove the lines for the brake fluid and pull the whole assembly out? Its not a daily driver so its no problem if its down for a week or two while the module is getting fixed. Cheers!
  5. #19
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Not been in that area myself but there are lot of help in this thread already. I am attaching a URL below if it is of additional help and shows how various parts are connected,
    http://www.compnine.com/index.php?u=...04&grouptype=B
    Good luck.
  6. #20
    xerods is offline Cadillac Owners Member
    Nov 2010
    43
    After I remove the EBTCM do I not need to bleed the brakes? I don't see any mention of that in any instructions.
  7. #21
    May 2005
    66
    343
    Quote Originally Posted by xerods View Post
    I believe the instructions in the following are pretty detailed and seem to indicate no touching of brake fluids,
    http://modulemaster.com/en/Cadillac/Catera_info.php
    The EBTCM just modulates braking pressure to prevent locking in support of the ABS operation. I believe the brakes still work without the ABS. Perhaps some of the experts can guide or you can contact modulemaster folks if you are getting yours repaired.
    Cheers.
  8. #22
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    It depends on what you actually remove.
    If you service the EBTCM with the hydraulic unit (BPMV) still mounted in the car, and you don't loosen any lines, then no.
    The EBTCM is a circuit board attached to several electromagnetic solenoids. The solenoids pull valves in the module but there is no direct physical link save for the bolts that hold the two pieces together.
    Basically the rule is, if you open a brake line, then you bleed it. If you don't then no need.
  9. #23
    Nov 2010
    43
    I did that the whole thing out. I have no idea how you would get it out with taking the BPMV out also.
    Thanks.
  10. #24
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Replacing the EBCM without taking the BPMV can be done, but granted on a Catera, either way it is a nightmare.
  11. #25
    Jared002900 is offline Cadillac Owners Member
    Automobile(s): 2000 Catera
    Jul 2010
    32
    7
    I took my EBTCM out of my Catera the other day. I followed a combination of the instructions provided on this thread. However, when I separated the EBTCM from the BPMV, I did not see any wave springs. Where are the wave springs located??? and do I need them?
    I found it easiest to take the two nuts off either side of the BPMV, that way I was able to pull the unit up a little bit to get to the middle screws. The bottom ones took a combination of extensions as stated earlier in the thread.
    Also, here is a link to a company that rebuilds these for $50 on ebay. I am sending mine out tomorrow.
    http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MESE:IT
  12. #26
    conflicting is offline Cadillac Owners Member
    Automobile(s): 1996 cadillac sts, 2003 cadillac cts
    May 2011
    vancovuer wa
    36
    6
    nice info!!
  13. Remove Advertisements
