I was a little late in reading your post
Oil cooler replaced, looks like my coolant leak is solved. Will need to drive for a while. I did not seal the thermostat with the RTV, gasket should hold for the remaining expected life.
I did bend the oil line slightly near the front of the block a bit to get the oil cover off. During installation, I started block/oil line nuts then tightened cooler/oil line nuts, then went back and tightened block/oil line nuts.
I did notice smoke on the drivers side exhaust manifold (burning oil). I have my fingers crossed as there was some spillage when topping off the oil, time will tell. Your warning on the bend has me a bit concerned. (Is the leak resulting from bending due to a kinked/cracked line, or poor seal at the block/oil line nut???)
I replaced the Heater Control Valve even though it was not leaking (precaution).
Flushed radiator, and purged until water ran clear, replaced standard green anti-freeze with DEX-COOL.
Added a container Techron Fuel Injector cleaner and a filled-up of High Test...
Also checked the records and the timing belt tensioner recall was taken care of in 2002 at ~40K.
Anything else that will need attention on a 98 CAT with ~75K miles, or should I start a new thread...
Thanks Again
